I am required to use a throat mic for an engineering solution, but the mic output is too soft. I had been looking into amplifiers and selected the LM358 chip to try and boost the signal, but I think the noise from my circuit is over powering the mic's signal. I'm not very familiar with pre-amplifier selection for mics (let alone throat mics,) and I'd really appreciate any advice. I have listed some questions I have below, again any help would be greatly appreciated.
1. What type of amplifier should I be looking for? Should I be using an instrumentation amp instead of the LM358 (Dual Op Amp)? or are those amps effectively the same for my purposes?
2. Will I get greater noise reduction by choosing a better amplifier? or is a harsh hissing noise generally caused by a noisy power supply/ power lines? Are there any general tips for reducing noise?
3. How does one typically choose an pre-amplifier based on a microphone? Is it impedance based?
4. If the LM358 should be able to do the job, aside from adjusting the gain, how should I tune this chip so I am not getting so much noise?
Thanks!
And for further information:
