Other Parts Discussed in Thread: RC4580
Hi all
Would you mind if we ask TL972?
Please refer to the attachment file?
20171026_TL972.pdf
In the first place, should we confirm this query at Audio forum?
Kind regards,
Hirotaka Matsumoto
Hi all
20171026_TL972.pdf
Kind regards,
Hirotaka Matsumoto
Hi team
We guess that your team is so busy, however could you give us the reply?
Kind regards,
Hirotaka Matsumoto
Ivan san
Thank you so much for your reply!
And we were sorry to rush you.
With higher R2 the noise is gone? Or is it just reduced?
->As our customer's recognition, the noise is gone.(However, they might just not hear as the noise.)
This is intended for an inverting configuration, right?
->Yes, it is inverting configuration.
Kind regards,
Hirotaka Matsumoto
Ivan san
Thank you for your support always!
Our customer confirms these, so we will feed back soon.
Kind regards,
Hirotaka Matsumoto
Ivan san
We will attach the file as below.(Please refer to P3 to P5)
20171115_TL972.pdf
We appreciate your help always!
Kind regards
Hirotaka Matsumoto
Ron san
Thank you for your reply.
If all TL972 do this, then check your power supplies for this same noise.
->Yes, all TL972 do this. And then, our customer uses power source with battery or stabilized power supply. The result was the same.
And, our customer uses shielded cables. The result was the same.
As our customer's suggestion, it seems that TL972 emits the noise.
If you have some additional advice, could you give us?
Kind regards,
Hirotaka Matsumoto
Hirotaka-san,
I strongly believe that the power source wiring (even when using batteries) is not inside a faraday cage. The signal capture is likely a nearby cell phone. I was able to replicate a similar signal by putting TL972 amplifier in the cage and having power source outside cage.
Here is a 100 dB gain output with cell phone close to power leads.
Due to the schematic differences between 972 and 4580, 4580 should have better power supply EMI rejection.
I saw greatly reduced output signal when doing the same test with Texas Instruments RC4580
Ron san
We told our customer to confirm with the cage.
We will feed back you as soon as we can.
Kind regards,
Hirotaka Matsumoto
Ron san
Thank you so much for your support!
Our customer could confirm your saying.
Kind regards,
Hirotaka Matsumoto
