OPA541: Part being damaged.
Part Number: OPA541
I use an OPA541 in a design, and it keeps getting damaged. I"m running it with a single ended supply, and after it's damaged either the output or the current sense pin are low impedance to +Vs or -Vs.
On a FET spec, the SOA  graph usually has a time associated with the curves. The OPA541 only has one curve. Does this mean it's a hard limit, and should never be exceeded, or can it be exceeded with a low duty cycle?
I'd like to have a way to send you schematics and more detail in private.
