Other Parts Discussed in Thread: LM234, LM258, LM321, LM358, , , TS321, LM358-N, TLV27L1
Is there an IC made that has the same circuit as the LM234/358 op-amp circuit only there is only one on the IC and it possibly would have offset adjustment?
Hi Andy,
I wanted to correct my previous post - the single channel version of the LM358 is the LM321. It does not have offset adjustment however. If you can provide more details on your application, I'd be happy to help recommend an op amp which fits your needs.
-Paul
Andy,
TLV27L1 could be a good choice due to its wide VCC range 2.7V to 16V, low supply and input bias current. It is much slower however.
