• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Amplifiers » /etc... Amplifiers & Other Linear » /etc... Amplifiers & Other Linear Forum » 4-20ma variable output driver
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
This question has suggested answer(s)
greg milne68714
Posted by greg milne68714
on Mar 08 2011 20:04 PM
Prodigy30 points
Most industrial interfaces use the 4-20mA interface as a discrete interface to represent 0s and 1s with those two levels.  I need to have an interface to a 4-20mA input, that can vary at least 1.6mA increments from 4-20mA.  4mA represents a off state, and 20ma is a full on state, and I need to be able to vary throughout this range, with fairly course steps.  I would rather have 0.8mA increments throughout that range to give me better resolution.  Is the load looking into a 4-20 interface standard?  Is it resistive at a fixed load?  I'm not familar with this type of interface.  I assume I need a voltage source, perhaps a DAC, and then a current driver of some sort.   Any help will be appreciated.
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Ian Williams
    Posted by Ian Williams
    on Mar 09 2011 12:09 PM
    Genius14245 points
    Hello Greg,
    Thank you for your interest in a 4-20mA transmitter. We have a variety of parts available which can output any current within the 4-20mA range, so achieving 0.8mA increments will be no problem as long as the input signal is configured properly. The load of a 4-20mA transmitter is commonly a 250-ohm resistance, so then by Ohm's Law a voltage drop of 1-5V is created which can easily be measured. However, some 4-20mA receivers such as our RCV420 have a lower input resistance and then create the desired output voltage with an internal transimpedance amplifier.
    It sounds like you plan on using the transmitter to control a remotely-located piece of equipment, such as a valve. Is this the case?
    Ian Williams
    Linear Applications Engineer
    High Performance Linear
    RCV420 4-20mA transmitter
    Report Abuse
    • Reply
  • greg milne68714
    on Mar 09 2011 13:49 PM
    Prodigy30 points
    Hi Ian,
    You are correct, the load is rated at 250ohms (according to my customer) and yes, I am controlling a remote industrial control mechanism with the 4-20mA interface.  I will take a look at the RCV420 device and if that is a family of devices, I will look at those as well.   What I don't know about, is if my load device has a power source integrated (Type 2) or if I have to provide the voltage source (Type 3, Type 4) into a passive load.  Also my customer described a 0-20mA control mechanism?  Not sure how the load device will respond to 0mA or why I would want to use that.
    Thanks for the quick response, I appreciate that.
    Greg
    Report Abuse
    • Reply
  • greg milne68714
    on Mar 09 2011 14:02 PM
    Prodigy30 points
    Hi Ian,
    I just looked at the data sheet.  I need a transmitter, so I need a voltage to current converter.  This part is a receiver (RCV420).  Do you have a recommendation on a transmitter?
    Greg
    Report Abuse
    • Reply
  • Ian Williams
    on Mar 09 2011 14:41 PM
    Suggested Answer
    Genius14245 points
    Greg,
    The RCV420 is indeed a receiver - you asked in your original post about loads and whether they were fixed/standard, so I included the RCV420 as an example of a load with a non-standard input resistance.
    I'd recommend the XTR111 in your application. It is an easy-to-implement voltage-to-current converter that can be used for 0-20mA or 4-20mA output. 0-20mA might be preferred by the customer if a 0-5V range is optimal for the mechanism being controlled.
    We also have an EVM (evaluation module) for the XTR111 available here: https://estore.ti.com/XTR111EVM-XTR111EVM-Evaluation-Module-P1244.aspx
    Ian
    4-20mA XTR111 0-20mA
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
