High Speed Amplifier Application Notes
Genius 14240 points
Last updated:  08/04/2010
A list of TI publications related to high speed amplifiers and their applications can be found below. This list does not include all op amp-related application notes from TI nor does it include TI contributed articles in engineering trade magazines. For a more comprehensive list of op amp-related application notes available on the TI website, use the Technical Document Search. To find TI contributed articles, use the Contributed Articles Search.
General
  • Stability Analysis of Voltage Feedback Op Amps - sloa020
  • Noise Analysis for High Speed Op Amps - sboa066
  • Demystifying the Operational Transconductance Amplifier - sboa117
  • Using a decompensated op amp for improved performance - slyt174
  • Frequency response errors in voltage feedback op amps - slyt146
  • Making the Most of a Low-Power, High-Speed Operational Amplifier - sboa121
  • Designing for low distortion with high-speed op amps - slyt133
  • Calculating noise figure in op amps - slyt094
  • Importing a SPICE Netlist into TINA - slva424
Current Feedback Operational Amplifiers
  • Voltage Feedback vs. Current Feedback Op Amps - slva051
  • Current Feedback Amplifier Analysis and Compensation - sloa021
  • Current Feedback Amplifiers:  Review, Stability Analysis, and Applications - sboa081
  • Stabilizing Current-Feedback Amplifiers - sboa095
  • Expanding the usability of current-feedback amplifiers - slyt099
  • A Current Feedback Op-Amp Circuit Collection - sloa066
Layout and Passive Components
  • Effects of Parasitic Capacitance in Op Amp Circuits - sloa013
  • Reducing crosstalk of an op amp on a PCB - slyt190
  • PC Board Layout for Low Distortion High-Speed ADC Drivers - sbaa113
  • Measuring Board Parasitics in High-Speed Analog Design - sboa094
  • How (Not) To Decouple High-Speed Operational Amplifiers - sloa069
Filter Design
  • Analysis of the Sallen-Key Architecture - sloa024
  • Active Low-Pass Filter Design - sloa049
  • Active filters using current-feedback amplifiers - slyt081
  • RLC Filter Design for ADC Interface Applications - sbaa108
  • Filters for Data Transmission - sloa063
Transimpedance Amplifiers
  • Transimpedance Considerations for High-Speed Operational Amplifiers - sboa122
  • Compensate Transimpedance Amplifiers Intuitively - sboa055
Wireline Communication
  • Implementing a Variable-Length Cat5e Cable Equalizer - sboa125
  • A Numerical Solution to an Analog Problem - sboa124
  • Wireline Data Transmission and Reception - sboa123
  • A Powerline Communication Line Driver Requirement Overview - sboa120
  • Active output impedance for ADSL line drivers - slyt108
  • Large-Signal Specifications for High-Voltage Line Drivers - sboa126
ADC Input Drivers
  • Driving High-Speed ADCs:  Circuit Topologies and System-Level Parameters - slaa416
  • Fully differential amplifier design in high-speed data acquisition systems - slyt119
  • High-voltage Signal Conditioning for Differential ADCs - sboa096
  • Low-power, high-intercept interface to the ADS5424, 105-MSPS converter - slyt223
  • Low Power Input and Reference Driver Circuit for ADS8318 and ADS8319 - sboa118
DAC Output Buffers
  • Design for a Wideband Differential Transimpedance DAC Output - sbaa150
  • Interfacing op amps to high-speed DACs
    • Part 1:  Current-sinking DACs - slyt342
    • Part 2:  Current-sourcing DACs - slyt360
    • Part 3:  Current-sourcing DACs simplified - slyt368
  • Wideband Complementary Current Output DAC to Single-Ended Interface: Improved Matching - sbaa135
Fully Differential Amplifiers
  • Fully Differential Amplifiers - sloa054
  • Analysis of fully differential amplifiers - slyt157
  • Input impedance matching with fully differential amplifiers - slyt310
  • Output impedance matching with fully differential amplifiers - slyt326
  • DC Output Errors in a Fully-Differential Amplifier - slva417
  • FDA Applications:  Line termination, driving high-speed ADCs, and differential transmission lines - slyt143
  • Using fully differential op amps as attenuators
    • Part 1 - Differential bipolar input signal - slyt336
    • Part 2 - Single-ended bipolar input signal - slyt341
    • Part 3 - Single-ended unipolar input signal - slyt359
  • A Differential Op-Amp Circuit Collection - sloa064
  • Differential Op Amp Single-Supply Design Techniques - sloa072
Analog Video Amplifiers
  • Measuring Differential Gain and Phase (includes Primer on Composite Video) - sloa040
  • Video Designs Using High-Speed Amplifiers - sloa057
  • Video switcher using high-speed op amps - slyt098
  • hello ,
    I would like to ask you if it possible to group all these AN into one ?
    It is a tresor for analog designer .
    thanks
  • In reply to makdam ASFOUR:
    hi every one
    i know that opa656 is dual supply .now i want only use single supply .can i use it this configration. ??
    opa656 using for photodiode reflected laser light sense for ADC. opa656 using in noninvrting configration /
    help me
    thanks
    hiw to use ifor single and noninverting configration..
  • In reply to emmr engineer:
    To use the OPA656 with a single supply, you must apply biasing to make sure the input voltage range is satisfied. I recommend this article:
    http://www.edn.com/design/analog/4347861/Demystifying-single-supply-op-amp-design
    If your design allows AC coupling, you could employ the configuration used in Figure 2:
    3750.200380f2.pdf
    Hooman
  • photodiode sensor using OPA656 for Reflected Laser light.
    hi everyone
    i want make a reflected laser light sensor using opa656.i want use opa656 in single supply configration because my sensor output gives as a input for ADC. opa656 use in noninverting configration.
    help me please
    thasnks
    I think your problem is solved with the help of a  mechenic .so you are visit to any nearest shop of lenses or cameras shop.
