Other Parts Discussed in Thread: INA282,
is it possible to use the INA240 or INA282 in a configuration where the GND pin is a -Vs, supply at +Vs and REF1=REF2 = 0V = GND? (Vs=½(2.7V to 18V) = Dual supply = Split supply. Both parts are meant to be used in single supply mode.
I am concerned by the noise which typically will be present on the -Vs rail (similarly to the noise on +Vs) if that will couple into the signal. Because the PSSR is (obviously) not specified for this GND referenced part. As far as I can tell - DC wise it should work fine though.
The reason is that all my other parts are bipolar operation around 0V.
Any ideas are helpful.
