Part Number: INA214
Hi Sir,
May I learn from you that do we have a solution P2P with INA214 and can support at least 54V?
Thank you for your kindly help.
Edward Chen
Hello Edward, Thanks for reaching out on the forum. I am not sure what you mean by p2p. As for a TI-design, there are not any that I am aware. Some people may attempt to use a voltage divider between the shunt resistor and the device, but we typically advise against that. Why not use the INA240? It comes in a 100V/V gain, has a lower offset, and can handle up to 80V common mode without any supporting workaround chips.
Patrick Simmons, TI Sensing Products Applications Support
Getting Started with Current Sensing Video Training Series
TI makes no warranties and assumes no liability for applications assistance or customer product design. You are fully responsible for all design decisions and engineering with regard to your products, including decisions relating to application of TI products. By providing technical information, TI does not intend to offer or provide engineering services or advice concerning your designs.
In reply to Patrick Simmons:
Hi Patrick,
Sorry for misunderstanding, P2P means Pin to Pins solution,
Do we have a solution Pin to Pin with INA214 and can support at least 54V?
Thank you.
In reply to user4773172:
