Other Parts Discussed in Thread: TL082, TINA-TI
Hi Team,
Here is a application. A 1200Vdc should be attenuated to signal level and connect DSP A/D terminal. I'm learn the method there are:
1. Using the passive resistor and consist a divided circuit, after series a buffer to DSP,
2. Using differential input for OP ( TL082A, Set Gain 0.002 V/V) and series a buffer to DSP,
3. Using fully-differential amplifiers and series a buffer to DSP
4. ...
My questions are:
1. Weather have more solution for High voltage attenuator, how about each of solutions pros and cons?
2. For cost concern, I'm try to use solution 2 (TL082A, ). Can you advice It's a good option or not? What key parameters I should take care? How to estimate the amplifier stable?
3. Which topology are best solution for high high voltage input? Can I have the details and reasons? Tks.
Xiaobing (Eric)
