Hi Team,
Please help me answer the follow question from my customer, thank you so much.
The DC motor is controlled by an H-bridge circuit, and a high-accuracy current sensor used to detect the current flowing through the motor is being investigated.
Question 1) As a result of the survey, INA240 is the best. Is there a device with higher accuracy than this device?
Question 2) INA240 is an analog output, but are there any products with digital output with the same or better accuracy?
Question 3) The current system uses a closed-loop current sensor that uses a magnetic core and Hall element. This is to achieve high-accuracy current detection. Can the INA240 achieve the same or better performance? Sorry for the abstract question, but I'm worried about PWM noise as a concern.
Question 4) We will ask you for reference. What is the resistance value of the differential amplifier circuit?
Tom Liu
