Other Parts Discussed in Thread: OPA171, TLV2186, OPA333, OPA388, OPA325, OPA191
Hi all, I have a question about that using opa187 as buffer. I designed a simple buffer circuit with opa187 but my circuit does not work regular. For example, my supply voltage is 5 volt for opamp and my input signal is 1 volt DC, I can see 1 volt in my output of opamp. Input signal is 2 volt, my output is 2 volt. Input signal is 3 volt, output is 3 volt. Input is 4, output is 4 but if my input signal is bigger than 4,2 volt, my output signal is happening 4,99 volt directly. This is my problem. Why can not I see 4,2 volt in my output of opa187 . If I make supply voltage of my opamp as 7 volt, I can see 4,2 volt in my output but I want to see it while supply is 5 volt. I try my circuit in simulation and also it is not work. In simulation, while my input is bigger than 4 volt, my output show 3,97 volt.I can not understand it.Generaly, at simple general purpose opamp, if you set simple buffer circuit, your output signal will be your input signal and its output range will be beetwen your opamp supply voltages. I set my circuit as thinking so but it does not work. Do you have used opa187 before ? and do you have seen this problem ? Can you help me ?
