• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Amplifiers » High Speed Amplifiers » High Speed Amplifiers Forum » OPA output confused
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 4 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
    Filter for thought
    Posted 5 days ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters...
    Let’s take this driver out for a spin
    Posted 11 days ago
    Before I suggest a suitable op amp to drive an ADC, I look at...
OPA output confused
OPA output confused
This question is answered
HAN-CHE CHEN
Posted by HAN-CHE CHEN
on Mar 20 2012 02:46 AM
Prodigy10 points
THS6002
 THS4631
Why THS6002 Vo can't output same as THs4631 ?
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Luke Lapointe
    Posted by Luke Lapointe
    on Mar 21 2012 11:42 AM
    Verified Answer
    Verified by HAN-CHE CHEN
    Expert4200 points
    The first thing to note is that the THS6002 has both input and output voltage ranges. According to page 4 of the THS6002 datasheet, the input common mode range on a +/-15V supply is +/-13.4V min or +/-1.6V away from the rails. The single ended output swing similarly is +/-3.5V away from the rails. For a 0V to 15V setup, this would translate to about 1.6V to 13.4V input range and 3.5V to 12.5V output range. A 4Vpp input signal and 2V DC offset will be violating the low side input common mode range spec, and with a gain of 2.54V/V, the output ideally would be sitting at 5.08V DC offset and 10.16Vpp which would also violate the output common mode spec. However, if you've already violated the input common mode spec and input gets clipped on the low side, the DC level of the signal would be shifted up which in turn would cause your output to be sitting at a much higher DC voltage and thus potentially violating the output common mode spec on the high side . This looks like what you are seeing for the THS6002 case. If you add a negative rail to give yourself more margin, you can get by without these problems.
    For the THS4631, the same concerns apply. Refer to page 4 of the THS4631 datasheet for the input and output voltage ranges.
    Luke Lapointe
    THS4631 ths6002 common mode range clipping
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
