• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Amplifiers » High Speed Amplifiers » High Speed Amplifiers Forum » THS4520 spice model
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    This amplifier doesn't exist...now what!?
    Posted 1 day ago
    by Xavier Ramus
    Sometimes it’s impossible to find an amplifier with the...
    Cable equalization 101 – Automating your design
    Posted 3 days ago
    by Hooman Hashemi
    Judging by the number of views on a post related to numerical...
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 7 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
THS4520 spice model
THS4520 spice model
This question has suggested answer(s)
Moshe Avigdor89344
Posted by Moshe Avigdor89344
on Apr 22 2012 01:04 AM
Prodigy70 points
We see that the THS4520 out can go to negative voltage but we simulate only with +5v and GND...
Simulate with Tina.
BR
Moshe
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Luke Lapointe
    Posted by Luke Lapointe
    on Apr 23 2012 14:40 PM
    Suggested Answer
    Expert4200 points
    Hello Moshe,
    On a 0V to 5V supply, the THS4520 output is limited to 0.25V to 4.75V typical. The output can get a little closer to the rails, but it can't go below or above the rails.
    Keep in mind, the differential output voltage can be negative because it is a mathematical expression (Vout_diff = Vout+ - Vout-). If Vout- is larger than Vout+, the differential voltage will be negative, but each output can only swing about 0.25V away from each rail.
    If there is something else going on, you can upload your TINA schematic we can take a look.
    Luke
    Report Abuse
    • Reply
  • Moshe Avigdor89344
    on Apr 23 2012 23:37 PM
    Prodigy70 points
    Hello Luka,
    We use the THS4520 test Circuits.
    If you test and run it with VEE=0v and Vcc=+5v you will see that the output (refer to GND, not diff) can go to -1v or lower than the Vee...
    This is great opamp with internal negative power supply?  :)
    BR
    Moshe
    Report Abuse
    • Reply
  • Luke Lapointe
    on Apr 26 2012 12:33 PM
    Expert4200 points
    Moshe,
    There is no internal negative supply for the THS4520. Remember that there is a passive path from input to output. What is your input voltage? Also, what voltage are you applying to the Vocm pin? If you upload your TINA schematic, that would be helpful.
    Luke
    Report Abuse
    • Reply
  • Hooman Hashemi
    Posted by Hooman Hashemi
    on Apr 26 2012 14:26 PM
    Expert4040 points
    Hi All,
    The THS4520 Macromodel shows output swing to be confined to the supply rails (as it should). Using the attached Test Circuit built in TINA with 5V single supply (Vocm= 2.5V), each output swings from 0.25V to 4.75V (again, as it should). In the image below, VP_8 and VP_10 are the outputs. I don't see swing below ground!
    Hooman
    3021.THS4520.TSC
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
