• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Amplifiers » High Speed Amplifiers » High Speed Amplifiers Forum » OPA4830 doesn't work
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    This amplifier doesn't exist...now what!?
    Posted 19 hours ago
    by Xavier Ramus
    Sometimes it’s impossible to find an amplifier with the...
    Cable equalization 101 – Automating your design
    Posted 3 days ago
    by Hooman Hashemi
    Judging by the number of views on a post related to numerical...
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 7 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
This question is not answered
Kaspars
Posted by Kaspars
on May 09 2012 08:07 AM
Intellectual820 points
I bought operational amplifier OPA4830. TSSOP14 package with 4 operational amplifiers inside. Datasheet: here
1st - OP AMP I use as a summer
2nd - integrator
3rd - trigger
4th - voltage follower
I use +/- 5V power supply and when I turn it on, the chip become hot and strange sound comes from it. Also in Power supply display shows current consumtion: 0,11A!!!
When I use other OP AMPS in the same PCB, for example (LM324N), everything works fine, so in circuit there isn't problem.
Any ideas?
Thanks.
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Avi Chami1
    Posted by Avi Chami1
    on May 09 2012 09:09 AM
    Mastermind7405 points
    How sure are you regarding the +/- 5V levels? The chip is designed to work with tight voltage, at +/- 5.5V at most (The LM324 range is larger).
    Could it be that the device was damaged on another board and now it is not working anymore?
    Are you completely sure regarding pin #1 position? Could it be that it was placed at 180 degrees rotation?
    Sorry for asking silly questions, but I have seen this workmanship mistakes many times.
    Report Abuse
    • Reply
  • Kaspars
    Posted by Kaspars
    on May 10 2012 01:39 AM
    I use very good power supply, so I'm very sure about voltage levels:
    I think the device couldn't be damaged, becouse I tested a few OPA4830 OP AMPs.
    About pin #1 postion I'm sure, I checked it several times.
    I think maybe there is problem with OP AMPs circuits, becouse, for example, I can't make voltage follower and integrating Op Amp circuits becouse of input resistance in current feedback Op Amps, it's too low (16ohm inverting input impedance). But OPA4830 isn't current feedback and it has 10k-400k ohm impedance.
    So maybe there is something that I don't know?
    Please help.
    Report Abuse
    • Reply
  • Avi Chami1
    on May 10 2012 03:38 AM
    From some simulations I did using TINA-TI and the 830 model, it seems there are problems using this opamp as integrator... but I don't understand why. Did you try to simulate your circuit?
    Report Abuse
    • Reply
  • Kaspars
    Posted by Kaspars
    on May 11 2012 03:47 AM
    I made all circuit in TINA-TI with OPA830, and simultation worked very well in Transient analysis. I'm new in this program, so what I should something else?
    Also, why TI employers ignore this post?
    Also I solder new PCB with OPA4830. First of all I added only power supply: U+ = +5V, U- = -5V. Everything seems to work well, except it consume 0,01A.
    Then I added sumator. Everything ok.
    Then integrator. It started to become a little hot at +/-5V, but it worked fine at +/-2,5V.
    Then I aded comparator. Everything ok.
    Then voltage follower and negative feedback to summator and it becomes rapidly very hot at +/-5V and all circuit consume 0,12A. When I use +/-2,5V it doesn't heat, but output is very noisy and seems it doesn't work like it should and like it was in simulations. Current consumtion - 0,08A.
    Any ideas?
    Thanks for helping.
    Report Abuse
    • Reply
  • Luke Lapointe
    Posted by Luke Lapointe
    on May 11 2012 10:53 AM
    Expert4200 points
    Kaspars,
    See the thermal information listed on page 6 of the OPA4830 datasheet. ΘJA = 95 °C/W. If you supply +/-5V with 10mA current draw with no external connections, then the device is dissipating 9.5°C. As you add extra circuitry around the device, the power dissipates through the external passive components and the ground plane. Using a lot of copper for the ground plane is a good way to dissipate this heat as well as picking larger passive components that are rated for higher power. Have you looked at the board with a thermal camera to see where the hotspots are?
    As a check, you can upload your TINA schematic and we can take a look.
    Luke
    Report Abuse
    • Reply
  • Kaspars
    Posted by Kaspars
    on May 17 2012 02:21 AM
    I use 0402 components.
    Report Abuse
    • Reply
  • Kaspars
    Posted by Kaspars
    on May 22 2012 02:18 AM
    Anyone?
    Report Abuse
    • Reply
  • Luke Lapointe
    on May 22 2012 14:17 PM
    Expert4200 points
    Kasparas,
    After looking at the circuit, I am not really sure what you are trying to accomplish. The connection from the output of the voltage follower back to the input of the first amplifier adds a large DC component (either the positive rail or the negative rail from the comparator) to your sine wave. This will cause the signal to bump against the input common mode range limits of the amplifier and clip, which will additionally cause the waveform to look very distorted and strange.
    The second thing I notice is that in your comparator stage you have positive feedback, which is not neccessary for a comparator. Positive feedback is generally a source of instabillity and can cause strange problems in your circuit.
    What is the purpose of this circuit?
    Luke
    Report Abuse
    • Reply
  • Kaspars
    Posted by Kaspars
    on May 23 2012 01:18 AM
    Ok, thanks.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
