• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Amplifiers » High Speed Amplifiers » High Speed Amplifiers Forum » ADC Driver
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    Cable equalization 101 – Automating your design
    Posted 1 day ago
    by Hooman Hashemi
    Judging by the number of views on a post related to numerical...
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 5 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
    Filter for thought
    Posted 7 days ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters...
ADC Driver
ADC Driver
This question is answered
kyle aven88804
Posted by kyle aven88804
on Jul 20 2012 12:31 PM
Prodigy80 points
I need to design an fully differential ADC driver that can handle a +/-15V input signal. I was looking at the THS4130 as an option. I need the design to be as low power and low noise as possible. I was thinking of using power rails lower than +/-15V (due to the fact that more ICs are available) and maybe using a voltage divider on the input signal before the diff driver. Does anyone know what noise implications this would have. I also would like to know what the minimum stable gain of the THS4130 is. I havent seen it noted in the datasheet.
thanks
kyle
THS4130
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Luke Lapointe
    Posted by Luke Lapointe
    on Jul 23 2012 10:29 AM
    Expert4200 points
    Hello Kyle,
    For +/-15V rails, the THS4130 is probably your best bet with 1.3nV/rtHz and 14mA quiescent current. It is also unity gain stable with 150MHz of bandwidth. If you can afford to lower your supplies significantly then there are other options. The next step down would be 15V supply, then 12V, although you might start losing dynamic range depending on the ADC.  What is the full scale input for the ADC?
    Luke LaPointe
    Report Abuse
    • Reply
  • kyle aven88804
    on Jul 23 2012 11:11 AM
    Prodigy80 points
    Luke,
    Thanks for your timely reply. I am more interested in using a gain lower than unity, more like 0.167. I need to fit a +/-15V signal into the ADS1278. I would prefer to do this with just one amplifier instead of multiple stages. The device is 16 channels so the more stages i need for each channel equates to a significant power increase. How would you address this problem?
    thanks
    kyle
    Report Abuse
    • Reply
  • Luke Lapointe
    on Jul 23 2012 11:24 AM
    Verified Answer
    Verified by kyle aven88804
    Expert4200 points
    Kyle,
    If you want to attenuate the input signal, your best bet is an input divider stage before the amplifier. There is a good article series in the Analog Applications Journal (http://www.ti.com/general/docs/gencontent.tsp?contentId=29569):
    Using fully differential op amps as attenuators, Part 1: Differential bipolar input signals (http://focus.ti.com/lit/an/slyt336/slyt336.pdf)
    Using fully differential amplifiers as attenuators, Part 2: Single-ended bipolar input signals (http://focus.ti.com/lit/an/slyt341/slyt341.pdf)
    Using fully differential op amps as attenuators, Part 3: Single-ended unipolar input signals (http://focus.ti.com/lit/an/slyt359/slyt359.pdf)
    In addition, the ADS1278 is a 6V max device. If you use this with a 5V supply and Vref of 2.5V, then the FSR input will be +/-2.5V. Most of our fully differential amplifiers can be driven off of 5V as well which would simplify the power aspect of the design.
    The THS4521 is a low power device (1.2mA quiescent current) and a very good driver for the ADS1278. Combined performance data can be seen in the applications section on page 34 of the THS4521 datasheet. There is also a dual (THS4522) and quad (THS4524) version of this device.
    Let me know if this route works for you!
    Luke LaPointe
    Report Abuse
    • Reply
  • kyle aven88804
    on Jul 23 2012 14:50 PM
    Prodigy80 points
    thank you Luke. Only other question is do you know where i can find the Spreadsheet that is mentioned in slyt336. it is not in the zip folder
    Report Abuse
    • Reply
  • Luke Lapointe
    on Jul 23 2012 14:56 PM
    Expert4200 points
    Kyle,
    The attachments are embedded within the PDF.
    Luke LaPointe
    Report Abuse
    • Reply
  • kyle aven88804
    on Jul 25 2012 11:19 AM
    Prodigy80 points
    sorry to keep coming back to this thread, but i need to make sure of one more thing before i move forward with my design. Do you know the stability problems that will arise (if any) if the THS4130 is run at a gain lower than unity.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
