Dears
Could you please let me know the θjc and Ψjt of THS9000.
I need it to evaluate as soon as possible.
Best Regards
Koji Hori
Dears
Best Regards
Koji Hori
HelloKoji,
I checked our package database and I could not find those parameters for this part. Are you using the DRW package?
I will have to check to see if someone can help me get this information.
Loren
Dear Loren-san
Thank you for your prompt reply.
Yes I'm using DRW pckae.
I'd really appreciated if you could continue to confirm this.
I'm looking forward to getting your reply.
Best Regards
Koji Hori
Hello Koji-san,
I put in a modeling request with our packaging group. The turn around time is two weeks.
Loren
Dear Loren-san
Thank you very much for your support.
I'm looking forward your feedback in two weeks.
Best Regards
Koji Hori
Hello Koji-san,
I have not seen the results of my request yet. I will have to check, I have never done a thermal modeling request before, so maybe I am not looking right place for the results.
Loren
Hello Koji-san,
I found the results of the modeling request. They are posted below.
Loren
Result- Theta JA-High K (standard datasheet value) |
128.0 |
Result-Theta JC, top (standard datasheet value) |
147.2 |
Result-Theta JB (standard datasheet value) |
94.5 |
Result- Psi JT (standard datasheet value) |
16.9 |
Result- Psi JB (standard datasheet value) |
95.0 |
Result-Theta JC, bottom (standard datasheet value) |
21.2 |
Dear Loren-san
Thank you very much for your reply and cooperation.
I'm really appreciated your support.
Best Regards
Koji Hori
Hello Koji-san,
The units are in Degrees C per Watt for all of the Theta numbers.
I am not familiar with the Psi units, but they should be in Degrees C per watt as well. Unfortunately the report from the modeling group had no units.
The document below shows units of Degrees C per Watt for all thermal units:
Loren
Dear Loren-san
Thank you very much for your prompt reply.
Your document is very helpful for my understand.
I really appreciate your support .
Best Regards
Koji Hori
