Hello everyone,
I have been looking through the datasheet of the LM7171 for 2 days and I have not come across the parameter that specifics what the output low voltage for this op amp is. I know that most op amps are not rail to rail and the output usually sits some voltage above 0 V (assuming our supply is 0 on the V- and 5 on V+)
Anyone who has an LM7171, how much does the output sit above 0 V when you do not have any signal at the input of the terminals? As in, what is the lowest voltage the op amp can output?
