We need some clarification on the THS4522IPWR part in terms of setting the common mode voltage.
We would like to set the voltage by adding a pulldown resistor of 150k to the VOCM pin. This assumes the part has an internal resistor divider network as described on the datasheet. We tried it in the lab and it appears to work but I think that process and tolerance inside the part will make the voltage we set vary a bit by device.
For our present application we just need the common mode voltage to be stable (DC) and in the fairly large range of the ADC. Right now the default value of the part is outside that range however.
Please advise.
