Hi
Can you share the user guide for THS4513EVM? This is not available on website. Only datasheet is available currently.
Aji
Hi
Aji
Hello Aji,
On our website it says the EVM User's Guide is contained in the Datasheet. On page 31 of the datasheet there is a schematic and sketches of the board layout. The BOM is on page 32. It does look like the rest of the user's instructions are missing.
Did you have a specific question?
The board will require a bench power supply connected to the Vcc and Vee banana plugs. For split supply there needs to be a ground connection as well.
If you give me details of the desired test you want to run I can let you know how to connect or configure the board.
The stock configuration appears to be set up for a single ended input on J2 and then a single ended output signal comes out on J3. For differential input and for differential output you will need to remove some components and install other components.
Loren
