I used VCA810 in projectsach as regulator of power level of RF. But sometching is incorect. My RF link contain : DDS(source) -> direfential-to-singe operational amp -> low pass filter -> VCA810(end). But when I adjust VCA gain in my signal harmonics go to hugh level. I measure witch VNA impedance and there is 3ohm-j23ohm. My RF patch is calculated to 50ohm. Signal have around 13MHz.
Can you help my witch matching output impedance to 50ohm? Becouse i thing that is the case of bad signal THD
I need topology or meybe corect connection.
