OPA657 current noise in TINA-TI v9 seems to be wrong
Other Parts Discussed in Thread: OPA657, TINA-TI, OPA656, THS4001
Dear Support,
I am doing noise simulation with TINA-TI v9 of the op amp OPA657.
I have compared the noise performance obtained by simulation versus the datasheet.
In doing that, I followed the scheme suggested by Art Kay in his many papers/slides.
The voltage noise looks correctly modeled, however the current noise is higher by 3 order of magnitude.
It should be in the fA/sqrt(Hz) range and it appears to be few nA/sqrt(Hz).
Please find attached the TINA-TI v9 schematic showing the problem on the (input) noise simulation of OPA657. On the schematic you also find the noise specs form the datasheet and the simulation results (both voltage and current noise referred-to-input). Voltage noise model looks fine, while current noise is in the nA/sqrt(Hz) and it should be in the fA/sqrt(Hz). The CCVS gain has been set to 1. I look forward to hearing from you.
OPA657_noise_test.TSC
  • Hello alberto,
    Thanks for bringing this to our attention. Our modeling team is in the process of verifying our SPICE models for errors .The OPA657 is also on the list and we will add the OPA657 to the bug list and ensure it is corrected. The current projection is to have the OPA657 fixed by end of May.
    One minor thing I should add is that the OPA657 is a "decompensated amplifier" so is not stable in unity gain. Not a big deal here but once you start running dc/ac/transient simulations you should keep this in mind.
    -Samir
  • Dear Samir,
    thank you for your reply..
    Please, let me know as soon as you have the corrected model.
    Also, I would be grateful if you could suggest me an op-amp with similar
    specs and with a  fully working TINA-TI noise model, in order to
    start my noise analysis as soon as possibile. Does OPA656 have a fully qualified
    TINA noise model (both current and voltage) ? Any other suggestions ?
    The voltage follower configuration you have seen in my TINA schematics
    has only be used to check the noise model. I am aware that OPA657 is
    unstable for A>7.
    Kind Regards,
    Alberto
  • Alberto,
      The OPA656 will also suffer from the same issue. Can you provide me with a schematic of your circuit and I will look to see how I can back calculate the correct total system noise.
    -Samir
  • Dear Samir,
    thank you for your help.
    Please find attached the TINA schematic of the circuit. It is a TIA based on the
    BurrBrown's classic embedded gain architecture. The TIA is intended to
    amplify the 1/f current noise of MOS transistors. The TIA output goes to a
    signal analyzer giving the noise power spectral density (nV/sqrt(Hz)) in the
    range: 0->100 KHz.
    The Rsource (see schematic) is > 1 MEG, I guess OPA657 is the best
    candidate. Any advice is very very welcome.
    I would like to estimate current and voltage noise Referred-to-Input.
    Kind Regards,
    AlbertoTIA_noise_bench.TSC
  • Alberto,
    The closed loop bandwidth of your 1st stage seems to be only 250kHz. At that point the OPA657 noise is around 1fA/rtHz which is very close to what is specified in the datasheet. Even with your 20MOhm resistor the output noise due to current noise is 20nV/rTHz. The thermal noise due to the resistor is around 500nV/rTHz! I don't think you need to worry about the current noise error in your particular case. Do you agree?
    Also, when I look at the OPA657 + THS4001 circuit it looks like you have 2 cascaded amps in negative feedback which is positive feedback. I think you need to reverse the polarity of the THS4001 amp.
    The current noise of a FET is extremely difficult to measure and challenging....what is the magnitude of the current you are expecting to measure? One thought is rather than working with a transimpedance amplifier which is harder to compensate can you shunt the MOSFET with a large resistor, say 1MOhm and configure your amplifier as a voltage gain amplifier?
    -Samir
  • Dear Samir,
    -> you are right:.However, the TIA has an overall intended bandwidth of 100kHz, so that's not a problem
    -> yes, I agree. However, my concern is the 1/f contribution at VERY low frequency, say 0.1-1 Hz. Could it be larger of resistor
    thermal noise, such to cover my signal ?
    -> 657 is configured as inverting , 4001 as NON-inverting, so the composite amplifier is inverting, isn'it ?
    -> the current noise of the device we are going to test is in the range 10^-13 - 10^-11 A/sqrt(Hz), see attached file:
    -> thank you for your advise. I will look into it.
    Kind Regards,
    Alberto
  • Hello Alberto,
      Please see my responses below:
    However, my concern is the 1/f contribution at VERY low frequency, say 0.1-1 Hz. Could it be larger of resistor thermal noise, such to cover my signal ?
    -> The datasheet shows the noise to be flat down to 10Hz so I am not really sure what happens at lower frequencies. It is extremely difficult to isolate and measure the current noise at these levels. Datasheets don't usually publish this for this reason. One thing you can do is contact the manufacturer of the datasheet you attached here and see how they made the measurement for the 100pA level. I would be very interested in knowing this myself.
    -> Incorrect. Irrespective of inverting or noninverting config., the feedback is always negative. To make the feedback positive on the THS4001 you should have OPA657 drive its inverting input and put the feedback from the output to the noninverting input. This would be positive feedback.
    -Samir
  • Dear Samir,
    the plot attached to my previous reply has been taken from:
    IEEE ELECTRON DEVICE LETTERS, VOL. 36, NO. 4, APRIL 2015
    Evidence of Correlated Mobility Fluctuations in
    p-Type Organic Thin-Film Transistors
    Gino Giusi, Orazio Giordano, Graziella Scandurra, Sabrina Calvi, Guglielmo Fortunato,
    Matteo Rapisarda, Luigi Mariucci, and Carmine Ciofi
    The Authors are specialist of very low noise measurements. The device under test is a p-typeOrganic Thin-Film Transistor.
    We would like to be able to repeat their measures.
    Any advice is very appreciated !
    Alberto
  • Please, let me know if OPA657 noise model has been updated.
    If so, how can I dowloand the new model in TINA-TI ?
    Kind Regards,
    Alberto
  • Hi Alberto,
    I checked with the modeling team and they ran into some issues during the model fix. They are looking to fix it. They are working on a couple of parts in parallel trying to verify that the fix works on all of them with no issues. Can you please check back in a month or so? In case it gets done earlier I will let you know immediately. Sorry for the inconvenience.
    -Samir
  • Dear Samir,,
    t
    thank you for your quick reply.
    Indeed, this delay is for me quite a problem. I hope the team will make it as soon as possible.
    Please, let me know when you have news.
    Kind Regards,
    Alberto
  • Hi Samir,
    is there any news about OPA657 updated current noise model ?
    Please, let me know about this issue.
    Could you please alert the team working on TINA noise model ?
    Thank you for your time.
    Alberto
  • Alberto,
    Sorry to keep delaying this. I spoke to the modeling team and they have promised that this will be complete by July 18th.
    -Samir
  • Dear Samir,
    thank you so much.
    I hope they will keep the promise....
    Alberto
  • Hi Samir,
    I am wondering if the modeling team held his promise. Did they modify the OPA657 TINA model ?
    Are the noise specs now correctly modeled ?
    Thank you for your help.
    Kind Regards,
    Alberto
  • Alberto,
    I was promised an updated model this week. Once I get it I will run some quick checks to make sure everything is good and send you a draft copy.
    Samir
  • Dear Samir,
    this is a very GOOD news !
    Kind Regards,
    Alberto
  • Hi Alberto,
    I have been testing the model and a lot of minor issues look like they are fixed. With regards to the current noise we can get the noise to be flat at low frequencies but < 10kHz the noise begins to rise. We are now debugging the model to see where the problem could be. In the past we have usually ignored this since people don't care too much about the current noise of FET amplifiers. Can you please remind me if you were interested in the low frequency or high frequency behavior of the current noise?
    Samir
  • Dear Samir,
    Yes indeed, I am interested in a model giving reliable results for current noise at very low frequency. I am designing a TIA to measure
    1/f noise in organic FET transistor and I need to simulate the opamp behavior at very low freq. Current noise is important to us due to the fact the source impedance of the device-under-test could be quite high.
    Thank you for your help. Please let me know about this issue.
    Kind Regards,
    Alberto
  • Hello Albertoo,
    Here is the updated model.OPA657_20160801.TSC
