在LMH7602的数据手册中我们没有找到输出电流限制这项指标。我们需要知道这项指标,如果输出端短路,其内部是否有电流限制电路,保护其不至于被烧坏?如果有,那么限制电流是多少?
Hello Laisan,
Can you please repost your question in English?
Loren
Hi Vincent,
The LMH6702 does not have internal current protection. Current under 100mA will not damage the amplifier, provided that adequate thermal dissipation is provided.
Any load resistance over 40 Ohms should be OK for current.
Loren
