• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Amplifiers » High Speed Amplifiers » High Speed Amplifiers Forum » OPA380 vs OPA657 for general purpose photodiode TIA
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    How to determine the power at output of modulator from DAC back-off level
    Posted 23 hours ago
    by Habeeb Ur Rahman Mohammed
    Customers often ask how they can determine the power at the output...
    DAC Essentials: What’s with all this glitch-ing?
    Posted 5 days ago
    by Tony Calabria
    When designing with a digital-to-analog converter (DAC), you...
    This amplifier doesn't exist...now what?! - Part 2
    Posted 7 days ago
    by Xavier Ramus
    In Part 1 of this post, we looked at the theory involved in making...
This question is answered
Brad Crochet
Posted by Brad Crochet
on Dec 24 2010 21:39 PM
Prodigy20 points
Hello--
I'm trying to design a general purpose photodiode transimpedance amplifier for my laser optics lab, but haven't yet entirely mastered the art of the datasheet.  The OPA380 and OPA657 seem promising, but the difference in how the specs are given on the datasheets gives me some trouble in making an apples to apples comparison.  For what it's worth, here's some info on the applications I have in mind:
--Low End:  DC level measurements of changes in laser power (this is a relative, not absolute measurement).
--High End:  Small, fast (microsecond) changes in fluorescence levels (again, relative measurement).
--Interchangeable Photodioide:  In conjunction with a switchable selection of feedback capacitors, I'd like to be able to change between photodiodes for different purposes.
The 380 boasts "a transimpedance bandwidth of > 1MHz in most configurations" and a GBW of 90MHz, while the specs of the 657 show a Small-Signal Bandwidth of 90MHz at Gain = +20, and a GBW of 1600 for Gain > +40.  How does all this translate in TIA configuration with a 10 Mega-ohm resistor?  Is the 657 a hands-down better choice if an output DC offset of a few microVolts one way or another isn't an issue?
Thanks in advance for sharing some wisdom.  Have a great day.
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Kristoffer Flores
    Posted by Kristoffer Flores
    on Dec 28 2010 11:49 AM
    Verified Answer
    Verified by Jim Karki
    Genius9710 points
    Brad,
    Here is a good application note that may help you with your transimpedance amplifier design: Transimpedance Considerations for High-Speed Operational Amplifiers - sboa122
    The app note discusses gain, bandwidth, noise, and stability as they pertain to designing transimpedance (photodiode) amplifiers.
    The big difference here between using the OPA657 or the OPA380 is that you will be able to achieve roughly 4.2 times the transimpedance bandwidth with the OPA657 than with the OPA380 due to the much higher GBW (1600MHz vs 90MHz). Bandwidth can be estimated using eq. 12 on p. 5 of the application note.
    For the higher speed application where you need to detect fluorescence level changes in the time scale of microseconds, the OPA657 is a better choice. Since relative measurements are being taken, the OPA657 will be suitable for the DC measurements as well.
    How do you plan to implement the switchable selection of feedback capacitors and photodiodes? Do you mean that different boards will have different capacitor/photodiode combinations, or do you intend to use a switch mechanism to allow switching components on-the-fly? Switches will add capacitance and introduce possible leakage paths that may cause issues in the design.
    Report Abuse
    • Reply
  • Brad Crochet
    on Dec 28 2010 15:55 PM
    Prodigy20 points
    Thanks Kristoffer.  I'll have my nose in that app. note for a while to come I think.
    I haven't worked out all the details of the capacitors yet.  I've seen switchable feedback resistors in other designs, and I figured why not do the same with some low-value capacitors.  I could have different sizes/speeds of photodiodes around the lab, all set up to plug directly into the TIA circuit.  Once a photodiode has been picked for a given application, the feedback capacitor value could be selected that gives the best response for that photodiode.  I was planning on using an on-board switch like TS12A4514 in order to minimize the effect of the switches on the circuit.
    I'm still a little green with this stuff, so I'm sure there are things I'm not thinking of here.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
