• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Amplifiers » Precision Amplifiers » Precision Amplifiers Forum » 4127 and Log112 Calibration
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
The Signal blog
  • $core_v2_blog.Current.Name
    Pop Quiz!
    Posted 1 day ago
    by Bruce Trump
    Put away your books and take out a sheet of paper. Each question...
    Settling Time
    Posted 7 days ago
    by Bruce Trump
    Settling time is the time required for an op amp to respond to...
    Slew Rate—the op amp speed limit
    Posted 14 days ago
    by Bruce Trump
    Slewing behavior of op amps is often misunderstood. It’s...
This question is not answered
Calvin Patel
Posted by Calvin Patel
on Feb 14 2012 17:25 PM
Prodigy10 points
I have several questions, but let me first start off with a basic question based on the 4127 datasheet.
On page 6, figure 4, there is a 10k pot with a 100meg resistor used to bias the input current on pin 4. My question is why would you need to bias the input current as well as finely adjust the reference current. It seems like there should only be 2 things to adjust, the level shifting and the gain setting (thus there should only be two resistors to adjust?) What would happen if I just ignored the 10k pot with 100meg resistor in my circuit?
Second, lets say that I DO need to adjust all 3 parameters to finely calibrate the transfer function to the one desired. I am then lost when I look at the datasheet for the log112 or even the Log114. Using these datasheets (and simulations) I can determine the values of all the external components to use, but even then it seems to be missing the calibration part. What if my resistor values are slightly off, then I should need trimmers to finely adjust the transfer function to the one I want, but the data sheet doesnt say anything about fine adjustments to things such as the bias current. Now I know that gain cannot be adjusted (which is perfectly fine), but level shifting still needs to be addressed. Can someone explain to me why the new Log112 doesnt have notes on fine calibration (maybe it's because users are expected to level and gain adjust using an external stage?)?
The transfer function I am aiming for is Vout=-10 log (Vin) with input voltages from .1V to 10V, thus outputs would range from -10 to 10 Volts. Using the Log112, wit a transfer function of Vout=.5 log (I1/I2), I plan on making I1 my reference (2.5 volts through a 250k resistor making I1=10 microamp). Then, I can obtain I2 from my input voltages by using a 100k resistor (thus .1V->1 microamp while 10V->100 microamp). I can also add an external amp with a gain of 20, so then I arrive as Vout=-10 log (Vin)! Perfect. But unlike the 4127 (which is what I've been using), I am not sure of the adjustment procedures to ensure that my input resistor is exactly 100k or that my reference current is exactly 10 microamps.
Thanks for the help, I really appreciate it. Sorry if it is a bit confusing I can add more clarification if needed.
amp LOG112 LOG114 opamp transfer function log amplifier 4127 logamp
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • John Caldwell
    Posted by John Caldwell
    on Feb 16 2012 21:54 PM
    Expert6655 points
    Calvin,
    For the Log112 and the Log114 you could simply put a potentiometer (configured as a rheostat) in series with your input resistance and/or your reference resistance to allow for adjustment. However, using precision resistors (.1% or better) for your external resistors would be a far better solution than a series potentiometer in terms of drift over time and temperature. I should also point out that there is no need for an additional external amplifier to achieve your desired transfer function with the Log112 or the Log114 as both parts contain internal (uncomitted) amplifiers for this purpose (A3 in the LOG112, and A4/A5 in the LOG114).
    I will look into your question on the 4127 and post the answer here if I'm able to find an answer.
    John Caldwell
    Analog Applications Engineer
    PA Linear Apps
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
