• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Amplifiers » Precision Amplifiers » Precision Amplifiers Forum » General question: stability of a feedback system -- transimpedance amplifier
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
The Signal blog
  • $core_v2_blog.Current.Name
    Pop Quiz!
    Posted 2 days ago
    by Bruce Trump
    Put away your books and take out a sheet of paper. Each question...
    Settling Time
    Posted 8 days ago
    by Bruce Trump
    Settling time is the time required for an op amp to respond to...
    Slew Rate—the op amp speed limit
    Posted 16 days ago
    by Bruce Trump
    Slewing behavior of op amps is often misunderstood. It’s...
This question is answered
Wayne Chu
Posted by Wayne Chu
on Feb 15 2012 02:05 AM
Prodigy120 points
Hi all,
I need some validations on my understanding of feedback system stability.  Currently, I am trying to replicate the reference design of a transimpedance amplifier (see link below).  With most of the resources I have been reading about this topic, stability of a feedback amplifier depends on gain margin and phase margin.  Please correct me if I am incorrect on my understanding:  the intuitive way to evaluate stability is to look at  when the magnitude bode plot crosses the 0 dB line, the corresponding phase should be less than -180 degree -- thus constitute a positive phase margin; also, when the phase bode plot cross -180 degree, the magnitude should be less than 0 dB -- thus giving a positive gain margin.
My simulation resulted in the bode plot below, and both gain/phase margin are negative it seems, thus rendering the system unstable I think.  I am hoping my analysis is incorrect and there is an alternative way to assess transimpedance amplifier (current feedback amplifier?).  I have seen others mention looking the at the rate of closure, which look at the intersection of open-loop gain (A_OL) and 1/beta.  I am still trying to understanding how these values are obtained for a design.  I have found some good resource from the E2E forum (list at the bottom) but still having difficulty understanding it.  I have attached the TINA circuit file below if anyone is interested in looking at it.  Thank you for all the help in advance!
Reference design: http://e2e.ti.com/support/amplifiers/precision_amplifiers/f/14/t/158884.aspx#584443
TINA circuit TSC file: 6523.TunnelingCurrentPreamp.tsc.zip
Resource:
[1] Transimpedance Considerations for High-Speed Operational Amplifiers (PDF 193 KB)
http://www.en-genius.net/site/zones/acquisitionZONE/technical_notes/acqt_092407
[2] Operational Amplifier Stability, by Tim Green, Linear Applications Engineering Manager, Burr-Brown Products from Texas Instruments
http://www.ti.com/general/docs/litabsmultiplefilelist.tsp?literatureNumber=sboa122
Wayne Chu
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Collin Wells
    Posted by Collin Wells
    on Feb 15 2012 06:26 AM
    Genius15580 points
    Hi Wayne,
    Although you are close in your understanding in some areas, you are off in others.  The stability of a closed loop system requires looking at the loop gain of the circuit which is not equal to the circuit closed loop Vo/Vin transfer function.  The Loop Gain is equal to the difference between the AOL curve and the 1/Beta (inverse feedback factor).  You will probably recognize this term as:  AOL*B.
    The system stability is therefore determined based on the remaining phase margin when the AOL*B product is equal to 0dB.   Tim Green's paper's which you've reference go into great detail showing how to obtain the AOL, 1/B, and AOL*B curves which can then be used for stability analysis.  In short, you need to break the loop around the amplifier and look at the difference between the source input (injected at the point where the loop is broken), the feedback signal, and the output.  I suggest you continue your reseach on Tim Green's papers and I'm sure you will figure it out.
    Regarding your circuit, there are some obvious problems with your lack of negative feedback on the composite amplifier second stage that requires some heavy re-work.  You may have just flipped the terminals on accident so please double check the circuit.
    Hope this helps.
    Collin Wells
    Precision Linear Applications
    Collin Wells
    Report Abuse
    • Reply
  • Wayne Chu
    Posted by Wayne Chu
    on Feb 15 2012 23:04 PM
    Prodigy120 points
    Thanks Colin,
    I am still going through Tim Green's paper.  The first two parts of the paper seems to be most relevant in discussing how to obtain the open loop gain (A_OL) and 1/beta value of a circuit.  I followed figure 2.3 given in part 2 (p. 3) to change the circuit in order to conduct a loop gain test: 1) grounding the input, 2) place a high value inductor at the output (block low frequency signal), 3) put a voltage source with a high value capacitor at the start of the feedback loop.  The paper tests a first-order circuit, now my question is, how would I use the same technique for a n-order multistage amplifier circuit?  Do I test each amplification stage separately; if all stages are stable, then I can assume the entire circuit is stable?  Or, do I test the entire circuit together?
    I attached the modified TINA circuit, hopefully you can tell me if I am doing this correctly.  In it, I test for the second stage of amplification alone, where I defined N2(s)/N1(s) as A_OL and N3(s)/N1(s) as 1/beta.  Now, if I were to test both stages together, like N3(s)/N0(s), I will get a floating point divided by zero error, most likely because I am not suppose to measure open gain test like this.
    TINA circuit with open loop configuration:  8787.TunnelingCurrentPreamp-OpenLoop.tsc.zip
    Just curious, I cannot find the rest of Tim Green's paper (part 11 to 15), was that ever made available online?
    Thank you again and really appreciate your help!
    Wayne
    Report Abuse
    • Reply
  • Collin Wells
    on Feb 21 2012 10:51 AM
    Verified Answer
    Verified by Collin Wells
    Genius15580 points
    Hi Wayne,
    Sorry for the delay.
    I believe the majority of your issues lie within the first stage transimpedance amplifier and not the second stage composite amplifier that you've currently broken the loop on.
    A 1GOhm feedback resistor is not very realistic, but the zero that it causes with the input capacitance of the amplifier and photodiode capacitance leads to an unstable rate of closure between the amplifier's AOL and the 1/Beta terms.  This effect is described in the following articles:
    http://www.ti.com/lit/an/sboa055a/sboa055a.pdf
    http://www.eetimes.com/design/analog-design/4009969/Understand-and-apply-the-transimpedance-amplifier-Part-1-of-2-
    http://eetimes.com/design/analog-design/4009970/Understand-and-apply-the-transimpedance-amplifier-Part-2-of-2-
    Please see the attached circuit and results for how to perform a stability analysis of your first stage transimpedance amplifier.
    6675.Transimpedance - Stability.TSC
    Please let me know if there are other questions.
    Collin Wells
    Collin Wells
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
