• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Amplifiers » Precision Amplifiers » Precision Amplifiers Forum » AFE031 powerline communication
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
The Signal blog
  • $core_v2_blog.Current.Name
    Pop Quiz!
    Posted 1 day ago
    by Bruce Trump
    Put away your books and take out a sheet of paper. Each question...
    Settling Time
    Posted 7 days ago
    by Bruce Trump
    Settling time is the time required for an op amp to respond to...
    Slew Rate—the op amp speed limit
    Posted 15 days ago
    by Bruce Trump
    Slewing behavior of op amps is often misunderstood. It’s...
This question is not answered
Stephen Thomas
Posted by Stephen Thomas
on Feb 22 2012 23:43 PM
Prodigy220 points
I d like to build a power line communication card.i was exploring AFE031.
I have a analog communication interface that employs a 4 wire analog communication interface that transmits/receivies Plain Tones  via telephone lines.
I d like such that the same analog interface card should be able to select whether to use the  telephone wires or Power Lines for communication as the transmission media.
In such a case what will be the simplest solution to achieve the same?
So say
1.if im using telephone wires i will be using 4 wire standard interface.
2.if im using power line communication interface then
Can the same 4wire/2wire interface can be used to communicate to another Power line Card (say for eg employing AFE031).I ve seen a two wire interface in the same..Can i use it?
or shall i use the decoded signals in the digital domain in the analog card and shall employ some digital communication standard to communicate with the AFE031 in the power line communication card?
Thanks for any help
Stephen
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Edward Mullins
    Posted by Edward Mullins
    on Feb 29 2012 18:03 PM
    Intellectual2245 points
    Hi Stehpen,
    It should be possible to select between the two methods...it is probably best if you send to me a block diagram of the network showing your proposed 4 wire and 2 wire schemes.  Also when using PLC over the 2 wires what other voltages/signal will be present on those 2 wires?  Do you have any data rate requriements for the PLC and are you restricted to a particular range of carrier frequencies on the PLC?  Can you think of any coexistence concerns or coexistence requirements when operating over the 2 wire and 4 wire schemes simultaneously...i.e. do they both operate at the same time or always separate times?
    Ed Mullins
    mullins_ed@ti.com
    Ed Mullins
    Texas Instruments
    Applications Manager
    AIP - Sensing Products
    mullins_ed@ti.com
    Report Abuse
    • Reply
  • Anh-Tuan Phung
    Posted by Anh-Tuan Phung
    on Jul 22 2012 05:08 AM
    Prodigy65 points
    Hello Mullins Ed,
    we are building a Plc modem with afe031 and f28069. We a wondering that how to config the modem for a radial network (one master, multiple slaves). Is this in the data frame that we define the ip of each slave ?
    Secondly, what does TI means the Data concentrator ?
    With my best regards,
    Report Abuse
    • Reply
  • Jose Duenas Cuellar
    Posted by Jose Duenas Cuellar
    on Jul 26 2012 11:56 AM
    Prodigy420 points
    Hello Anh-Tuan Phun,
    My apologies for the delay in the reply; I am checking with our systems team to answer your radial network question.
    You can find more about our data concentrator solutions at: http://www.ti.com/lit/ml/slyt431a/slyt431a.pdf
    Jose Duenas
    Report Abuse
    • Reply
  • Wonsoo Kim
    Posted by Wonsoo Kim
    on Jul 26 2012 12:22 PM
    Prodigy450 points
    Hi Anh-Tuan,
    You can set a device to master or device by configuring it via host messages. Please, refer to the attached message sequence for G3.  With F28069, G3 can be configured as mini-DC (supporting up to 30 nodes) or device. For PRIME, it can be run as service node (slave) only on F28069. You will need our SGI platform to run as master node (Data concentrator). Using SGI platform for G3 or PRIME DC will allow you to support up to 1000 nodes.
    The Data concentrator means master.
    4024.Host Message Sequence.pdf
    Report Abuse
    • Reply
  • Anh-Tuan Phung
    on Jul 27 2012 04:46 AM
    Prodigy65 points
    hi Kim,
    thank you for your response. Because we are at the beginning of the development so that some questions may be very stupid. I am wondering that using G3 or PRIME, we must only concentrate on the content that have to be transfered. What happen with we want to develop a software that allow users to manage their system using PLC. For example we develop a smart home management system. How to config this with G3 or Prime.
    Thank you.
    PLC AFE031 F28069
    Report Abuse
    • Reply
  • Christian Wilhelmsen
    Posted by Christian Wilhelmsen
    on Nov 27 2012 07:48 AM
    Intellectual810 points
    Have you found a sollution to this? Just a heads up: if you are developing for applications in Europe you have to operate within CENELEC B/C/D and not A. Prime is only able to operate within band A.
    - Wilhelmsen
    Report Abuse
    • Reply
    on Nov 28 2012 09:38 AM
    Prodigy420 points
    Hello Christian:
    I noticed you have been communicating with one of our applications engineers from the systems team regarding a software question and source code availability for our TMDSPLCKIT-V3. Is this question related to that conversation? Could you please elaborate on this forum question? I do not fully understand it.
    Jose Duenas
    Report Abuse
    • Reply
    on Nov 28 2012 14:20 PM
    I am really sorry for the confusion, I see that I have accidentally posted this one here. This was meant to be at another thread.
    - Wilhelmsen
    Report Abuse
    • Reply
  • Bin Rua
    Posted by Bin Rua
    on Mar 31 2013 12:32 PM
    Prodigy195 points
    Hi TI Employee
    Can I use TI's PLC solution for DC power line or cold wire (no AC power, no DC power)? How high of data rate could I use for the distance of 5km?
    Thank you for your help.
    BinRua
    Report Abuse
    • Reply
    on Apr 01 2013 10:49 AM
    Prodigy420 points
    Hello Bin Rua,
    TI's PLC solution can be used on AC power lines as well as DC power lines.
    The achievable data rate is heavily dependent on the channel conditions. For the 5km line you mentioned, do you know the characteristics of the noise present on the line? Also, do you know how much attenuation will such line introduce on the PLC signal?
    The paper “Developing robust power line communications (PLC) with G3” has a comparison on the maximum data rates available for different communication standards typically used in utility metering applications.
    http://www.ti.com/webemail/2012/email/MCU-Power-Line-Comm/slay021_pdf_redirect.shtml
    G3 and PRIME standards are supported on our TI Power Line Modem Developer's Kit (TMDSPLCKIT-V3): http://www.ti.com/tool/tmdsplckit-v3
    Please do not hesitate to contact me if you have any further questions.
    Jose
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
