• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Amplifiers » Precision Amplifiers » Precision Amplifiers Forum » minimum input voltage on TLV2472
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
The Signal blog
  • $core_v2_blog.Current.Name
    Grounding Principles
    Posted 2 days ago
    by Bruce Trump
    In a previous blog on supply bypassing , I cautioned that poor...
    Handy Gadgets and Resistor Divider Calculations
    Posted 10 days ago
    by Bruce Trump
    Handy gadgets make our engineering life easier—the little...
    Chopper Op Amps—are they really noisy?
    Posted 17 days ago
    by Bruce Trump
    Chopper op amps offer very low offset voltage and dramatically...
This question is not answered
Simon Brethous
Posted by Simon Brethous
on Apr 02 2012 09:48 AM
Prodigy30 points
I'm working with the precision amplifier TLV2472 and I've been surprised to see that it's not working if the input voltage is less than 0.5V.
I'd like to know if this is normal and why. Also, if the amplifier really has a minimum input voltage, what is it exactly?
Thank you
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Marek Lis
    Posted by Marek Lis
    on Apr 02 2012 10:08 AM
    Genius13570 points
    Simon,
    TLV2472 has a rail-to-rail input common-mode range so the problem you see must be caused by your circuit configuration;  for example, if you use the part in a follower configuration, the circuit may in fact stop working properly when the input voltage is less than 0.5V above the negative rail, not because of the input range problem but because you may be exceeding the low-level output voltage (see below).
    If you have additional questions, please provide the full schematic including the supplies/input voltages used in your application.
    Marek Lis
    Sr Application Engineer
    Precision Analog - Burr-Brown Products
    Texas Instruments - Tucson
    Report Abuse
    • Reply
  • Simon Brethous
    on Apr 02 2012 10:21 AM
    Prodigy30 points
    Well, I don't think that this is the problem. The scematic used is the one below (without the current generator, that is a mistake). As you can see there is a gain between the minus input and the output so the voltage should not go below the low level. Do you have any other idea?
    Thank you
    Report Abuse
    • Reply
  • Marek Lis
    Posted by Marek Lis
    on Apr 02 2012 15:37 PM
    Genius13570 points
    Simon,
    You say you don't use the current input source shown in your schematic but then what is the actual VSRC input voltage?  If it is 5V then this is exactly the problem with your circuit that you drive the output into rail - just the positive one.  You have an attenuator of 1.2k/7.4k (0.162162) at the input and then a gain of 7.4k/1.2k (6.166667) at the output so that Vout/VSRC = 1;  R6 place no role in the overall gain and it acts only as a resistive load so I do not know the reason for including it.  If you use VSRC=2.5V, the output should follow at 2.5V and there should be no problem.
    Marek Lis
    Report Abuse
    • Reply
  • Simon Brethous
    on Apr 02 2012 16:20 PM
    Prodigy30 points
    Yes the VSRC Voltage is at 2.5V. The current generator is actually in parallel with R12 so that we can have a voltage depending on the current.
    The problem is, when ISRC=0 (whatever the vaue in fact) we have theorically V+= 2.5*1.2/7.4=0.4V.
    This value should be found on V- too, but we read 0.1V. After some test we found that if the value in the +input of the amplifier is below 0.5V we don't have the same on the -input (the amplifier is not working). And I really don't know why.
    We are thinking of reducing the atenuator to have a greater value but in this case we lose in precision for the current reading.
    Report Abuse
    • Reply
  • Marek Lis
    Posted by Marek Lis
    on Apr 02 2012 17:07 PM
    Genius13570 points
    If your VSRC is in fact 2.5V and the circuit loses its virtual short between the input terminals, one other possibility is that the supply voltage is 2.5V and not 5V as shown on the schematic.  Also, perhaps you should take TLV2472 out of its current configuration and test it as a follower sweeping its input voltage across the entire supply range while monitoring the output voltage.
    Marek Lis
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
