• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Amplifiers » Precision Amplifiers » Precision Amplifiers Forum » LMH6515 Evaluation board schematic
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
The Signal blog
  • $core_v2_blog.Current.Name
    Grounding Principles
    Posted 3 days ago
    by Bruce Trump
    In a previous blog on supply bypassing , I cautioned that poor...
    Handy Gadgets and Resistor Divider Calculations
    Posted 11 days ago
    by Bruce Trump
    Handy gadgets make our engineering life easier—the little...
    Chopper Op Amps—are they really noisy?
    Posted 19 days ago
    by Bruce Trump
    Chopper op amps offer very low offset voltage and dramatically...
This question is not answered
Jerry Lin
Posted by Jerry Lin
on Apr 11 2012 09:17 AM
Prodigy10 points
Just want to make sure is the C11 (FIGURE on EV board datasheet). of LMH6515 evaluation board shorted on the PC board ?
I check with multimeters, and it shows C11 is shorted, but not shorted in the datasheet.
Thank you !
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Paul Grohe
    Posted by Paul Grohe
    on Apr 11 2012 10:58 AM
    Expert4325 points
    Hello Jerry,
    C11 should NOT be shorted. Otherwise the transformer will short the power supply, and, if supply current is not limited, damage the transformer or L1/L2 bias inductors.
    C11 may measure as a short in-circuit because of the parallel path through the transformer and through the L1/L2 1uH bias inductors back through the part power supply pins to ground. You would have to remove C11 to see if it is truly shorted..
    Paul Grohe
    Integrated Signal Chain Applications, SVA
    Report Abuse
    • Reply
  • Loren Siebert 1
    Posted by Loren Siebert 1
    on Apr 12 2012 12:35 PM
    Intellectual1515 points
    Paul is correct.  Most likely you are measuring current flowing through other circuit elements.
    You may want to try swapping the test leads on your multimeter.  There is a Shottkey protection diode across the power pins that protects the amplifier from reverse polarity power supplies.  Your DVM may be measuring this diode, or it may be measuring current that is flowning into the amplifier.
    If you apply 5V to the power connnections what supply current do you read?  Is there any performance problem that leads you to suspect a short?
    C11 is not supposed to be installed when the board is shipped and it is not necessary.   With 5V applied to the power connectors there should be 5V reading at pins 1, 2 and 3 of T2.  If there is 5V at these pins and there is not excessive supply current then there is no short circuit.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
