• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Amplifiers » Precision Amplifiers » Precision Amplifiers Forum » EMG Amplification Poor Signal to Noise performance in full wave rectifier
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
The Signal blog
  • $core_v2_blog.Current.Name
    Grounding Principles
    Posted 9 hours ago
    by Bruce Trump
    In a previous blog on supply bypassing , I cautioned that poor...
    Handy Gadgets and Resistor Divider Calculations
    Posted 8 days ago
    by Bruce Trump
    Handy gadgets make our engineering life easier—the little...
    Chopper Op Amps—are they really noisy?
    Posted 15 days ago
    by Bruce Trump
    Chopper op amps offer very low offset voltage and dramatically...
This question is answered
Chad Knutsen
Posted by Chad Knutsen
on Apr 15 2012 01:51 AM
Prodigy140 points
I'm an engineering student but this is more of a personal project.  My grandma suffered a stroke recently and lost the use of her right arm.  She has very limited muscle contraction but enough that I think a myoelectric controlled assistive prosthesis would help in her recovery.  The circuit works as expected except at the full wave rectifier.  When I do the noise analysis in TINA-TI, the signal to noise ratio looks good at all stages except the final rectification stage.  The signal is going to a microcontroller so it needs to be a DC signal.  I've been working with a couple professors at school but haven't received any feedback on this issue.  I've setup the noise analysis as follows, frequency 1-500Hz, 500 data points, S/N Amplitude 1.5m.  I chose 1.5m for the S/N because I am figuring on amplifying a 1.5mV biopotential.   I guess I should ask if I'm doing the noise analysis correctly before asking about my circuit design.  Would that be correct for the S/N Amplitude?  At the output of the LPF I get a SNR of 33, but then after the rectification, at 150Hz the SNR is 0.731. I've attached the circuit that I used for the transient analysis that includes common mode, right leg drive, EMG potential, and DC offset, and I also attached the single source circuit I used for the noise analysis.  Please take a look and let me know if there is a better way of doing this.
Click the picture to see the circuit
EMG Amplification Circuit
Thank you, Chad K
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Bruce Trump
    Posted by Bruce Trump
    on Apr 18 2012 14:31 PM
    Mastermind20805 points
    Chad,
    Your schematic is difficult to read due to poor resolution. From what I can see in the signal path, noise performance should be determined by the first stage, INA121, assuming you have enough gain in this stage. I can't decipher your S/N figures but concentrate on acquiring a clean signal in the first stage. With adequate gain in this stage, its S/N will dominate.
    There may be problems with doing a noise analysis through the FWR, I'm not sure. It, by definition, is not a linear process. The op amp must slew through a dead band around zero. This may present some analysis issues.
    Regards, Bruce.
    EMG Amplifier
    Report Abuse
    • Reply
  • Chad Knutsen
    on Apr 18 2012 14:45 PM
    Prodigy140 points
    Here are the TSC files.  What does the S/N Amplitude mean in the noise analysis setup?  If I set it to 1.5m, does this mean my voltage source inputs a 1.5mV signal?  I notice that when I set the S/N Amplitude to 1.5m, my SNR at 150Hz is much lower that when I set the S/N Amplitude to say, 1.EMG AMP Circuit.TSC
    Report Abuse
    • Reply
  • Bruce Trump
    on Apr 19 2012 16:15 PM
    Chad,
    The S/N function plots the ratio (in dB) of the signal (the magnitude you specify in the setup of the simulation) relative to the integrated noise from the start frequency of the plot to the given signal frequency at which you are reading the plot. It's a bit obtuse. Anyway, when you supply a larger signal amplitude for the simulation the S/N will obviously improve.
    Your noise is dominated by the series input resistors which create about 110nV/rt-Hz. After that hardly anything else matters in your circuit. Furthermore, the macromodels for the amplifiers you are using do not model noise accurately.
    Regards, Bruce.
    Report Abuse
    • Reply
  • Chad Knutsen
    on Apr 19 2012 16:30 PM
    Prodigy140 points
    The raw EMG signal amplitude before amplification will be about 1.5mV, and after the INA121 Gain of 30, it will be about 45mV, then 4.5V in final amplification.  I'm a mechanical engineering student so I don't have a really solid understanding but I'm very interested in learning as I go.  The final stage seems to rectify first and then amplify by 100, is that right?  So when I chose the S/N Amplitude, would I chose the expected input of 45mV.  Or would I chose 4.5V?   If I'm just overcomplicating this, it would be just as helpful if you just said whether or not this circuit is going to be too noisy to amplify the 1.5mV EMG signal.
    Second, and last question.  What type of diodes would I use in this circuit?
    I really appreciate your help on this.
    Chad K
    Report Abuse
    • Reply
  • Bruce Trump
    on Apr 19 2012 17:01 PM
    Chad,
    You should not have any problems with noise. The principles of S/N mean that once you have developed significant gain in the circuit (the INA121), the noise of subsequent stages do not contribute any significant noise.
    The final rectifier stage performs both the gain and rectification, essentially in one step. I recommend signal diodes such as 1N4148. Do not use power rectifier diodes such as 1N4001.
    One final warning:  Be very cautious. Avoid using any power-line operated instruments or power supplies. I recommend that everything be battery powered. We don't want to fry Grandma. Commercial medical equipment uses galvanic isolation devices for safety when operating from AC power.
    Regards, Bruce.
    Report Abuse
    • Reply
  • Chad Knutsen
    on Apr 19 2012 17:28 PM
    Prodigy140 points
    Thank you for the warning.  I did find that issue come up a lot in my research but there wasn't any focus on battery powered circuits or USB powered circuits, just AC.  As of right now, everything is battery powered.  Would I need to use isolation if I added a USB connection?
    Report Abuse
    • Reply
  • Bruce Trump
    on Apr 19 2012 17:31 PM
    Verified Answer
    Verified by Chad Knutsen
    Chad,
    If you run from a laptop under battery power, you can power from its USB port. I do not recommend running off the charger.
    Bruce
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
