• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Amplifiers » Precision Amplifiers » Precision Amplifiers Forum » XTR110 span and zero adjust
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
The Signal blog
  • $core_v2_blog.Current.Name
    Grounding Principles
    Posted 4 days ago
    by Bruce Trump
    In a previous blog on supply bypassing , I cautioned that poor...
    Handy Gadgets and Resistor Divider Calculations
    Posted 12 days ago
    by Bruce Trump
    Handy gadgets make our engineering life easier—the little...
    Chopper Op Amps—are they really noisy?
    Posted 19 days ago
    by Bruce Trump
    Chopper op amps offer very low offset voltage and dramatically...
This question is answered
David Prince92104
Posted by David Prince92104
on May 15 2012 17:01 PM
Prodigy180 points
I am using two XTR110s in my product. The span adjust is barely large enough, and has a known interaction with the zero adjust. The zero adjust does not have enough range to make up for some voltage offsets that are created by the amplifers earlier in the circuit. I am using 100K ohm pot on the zero and 100k ohm pot and a 10k ohm resister on the span adjust.
Is there any way to increase the zero adjust range?
Thank you.
XTR110
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Collin Wells
    Posted by Collin Wells
    on May 15 2012 17:48 PM
    Genius15530 points
    Hi David,
    Just so we're on the same page, would you please include a basic schematic of your circuit as well as your desired Iout vs. Vin characteristics?  The span adjust on the XTR111 should be very configurable to a wide range of different desired output spans.  What is your desired output span?.    What is your desired final output range (4-20mA, 0-20mA, 5-25mA), and what is your system's input voltage that needs to produce this range?  With this information we can work towards a solution.
    Collin Wells
    Precision Linear Applications
    Collin Wells
    Report Abuse
    • Reply
  • David Prince92104
    on May 16 2012 16:04 PM
    Prodigy180 points
    Sorry about that. I have it set to the 0-5v input and 4-20mA output.
    R46 is a 10K ohm. The input, Pin 5, has a DC offset between 0.010 and 0.1 volts, this is making the zero adjust difficult. The highest voltage on pin 5 is about 4.7 volts, which is 19.6mA or so, that is fine. My PLC thinks 19.7mA is max value.
    The issue is, the DC offset is stressing the zero adjust and then the span adjust is pulling the zero up as well. So in most cases the zero adjust is turned to minimum and the device still wont put out 4mA, but if i turn the span adjust down it will go closer to 4mA. Can I make the zero adjust stronger?
    XTR110
    Report Abuse
    • Reply
  • Collin Wells
    on May 17 2012 07:45 AM
    Genius15530 points
    Hi David,
    Thank you for the additional information.  Although your goals seem like they should be pretty reasonable, I will need to go into the lab and test this out to be sure.  With my current project loading I think it will take until middle of the day tomorrow before I'm able to report back with any results.  In the mean time, please confirm this is correct.
    XTR110 Input: 0.1V - 4.7V
    Desired XTR110 Output:  4mA - 20mA.
    Collin Wells
    Collin Wells
    Report Abuse
    • Reply
  • David Prince92104
    on May 17 2012 15:08 PM
    Prodigy180 points
    yes that is correct.
    thank you,
    David Prince
    Report Abuse
    • Reply
  • Collin Wells
    on May 18 2012 16:28 PM
    Verified Answer
    Verified by Collin Wells
    Genius15530 points
    Hi David,
    I tested the circuit today and came to the same conclusion as you that the offset trim was simply not enough to get to 4mA with a 0.1V input while using the SPAN trim to get near 19.7mA with a 4.7V input.  I could only get the output down to 4.1mA or so.
    Luckily I had an idea.  Since you're using the 4-20mA mode and we're already offsetting the input to 4mA using the +10V VREF voltage and the internal resistors, why not decrease the effect of the 10V reference and thereby reduce the zero-scale output level?  This was achieved by adding a 2.2 kOhm resistor between the VREF_F (pin 15) output and the VREF_IN (pin 3) input.  It took a little bit of an iterative process to determine that 2.2 kOhms was the right resistor value because the SPAN and OFFSET trims interfere with each other.  The result was that the output was pushed down to 3.827mA when the input was 0.1V.  By adjusting the SPAN trim and the OFFSET trim potentiometers from there I was able to achieve a very accurate 4 - 20mA output with a 0.1V - 4.7V input.
    Let me know how it goes and if you're able to repeat my results.  I used the same values as you did, using 100k potentiometers, a 33 Ohm in series with the 16mA SPAN input, and a 10kOhm in series with the SPAN_ADJ pin.
    Collin Wells
    Collin Wells
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
