• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Amplifiers » Precision Amplifiers » Precision Amplifiers Forum » 2 Lead dry electrode ECG circuit
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
The Signal blog
  • $core_v2_blog.Current.Name
    Grounding Principles
    Posted 3 days ago
    by Bruce Trump
    In a previous blog on supply bypassing , I cautioned that poor...
    Handy Gadgets and Resistor Divider Calculations
    Posted 11 days ago
    by Bruce Trump
    Handy gadgets make our engineering life easier—the little...
    Chopper Op Amps—are they really noisy?
    Posted 18 days ago
    by Bruce Trump
    Chopper op amps offer very low offset voltage and dramatically...
This question is not answered
udhaya kumar a
Posted by udhaya kumar a
on Jun 07 2012 09:57 AM
Prodigy80 points
Hello TI,
I need a circuit design for a 2 Lead Dry contact electrode ECG system. I am selecting INAMP & OPAMP for the design. Please suggest me a very good working circuit & IC'S. Please I am not preferring ADSXXXX series.
My requirements are as fallows,
1. It is a handheld equipment with battery powered, so the power consumption should be less.
2. The production quantity is 2000 piece/month, so the cost of the chip & circuit should be very less.
3. The circuit should have very good reliability & repeatability.
3. The electrodes contact with thump [dry contact], so the sensitivity should be linear for all type of skins.
Please provide me necessary support to start my project....
Thanks & regards
Udhay
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Thomas Kuehl
    Posted by Thomas Kuehl
    on Jun 07 2012 18:30 PM
    Mastermind24290 points
    Udaya,
    We have a design that requires contact with both thumbs and oppossing fingers. Basically, this is a 3-wire connection with two being for differential input and one for common-mode drive. It is a dry contact system. Would this be of interest to you?
    Thomas
    PA - Linear Applications Engineering
    Report Abuse
    • Reply
  • udhaya kumar a
    on Jun 07 2012 23:54 PM
    Prodigy80 points
    Thomas,
                Thanks for the reply. Yes i am looking for that circuit. Can you share with me the recommended part number, ideas, application notes & the circuit diagram if possible.
                I am eagerly waiting for your reply...
    Thanks again
    Udhay
    Report Abuse
    • Reply
  • Thomas Kuehl
    on Jun 08 2012 10:56 AM
    Hi Udhay,
    Can you provide me your email address? I have a TI Tech Day ECG PowerPoint presentation that I would like to send directly to you. It contains the circuit information. It is a very large file and I may need to do some work on it to get it down to a size that doesn't get blocked by our system.
    If you do not wish to list your email address on the forum, send a message to me at mine:
    kuehl_tom@ti.com
    Regards, Thomas
    Report Abuse
    • Reply
  • udhaya kumar a
    on Jun 09 2012 00:09 AM
    Prodigy80 points
    Dear Thomas,
                  Please send me the information to my email address (udhay@trock.in). If any EVB kit available please share the detail also...
    Thanks & regards
    Udhay
    Report Abuse
    • Reply
  • udhaya kumar a
    on Jun 10 2012 23:42 PM
    Prodigy80 points
    Thomas,
                   Sorry my email id ( udhay@trock.in ) Can you resend the email please....
    Thank you
    Udhay
    Report Abuse
    • Reply
  • Thomas Kuehl
    on Jun 11 2012 10:31 AM
    Hi Uday,
    The ECG presentation will be sent to the email address you have provided. The ECG board was developed for demonstration purposes and was never produced as a EVM. I do think there is enough information in the session that you should be able to construct your own prototype.
    Note that in the presentation the INA326 instrumentation amplifier is used in the ECG circuit. It is fine for the application, but a newer higher performance instrumentation amplifier is now available, the INA826. It uses much less power and has lower noise than the INA326. You may wish to consider the newer device for your application. The pin-outs are different and some other minor circuit changes may be required to use the INA826.
    Regards, Thomas
    Report Abuse
    • Reply
  • udhaya kumar a
    on Jun 12 2012 03:38 AM
    Prodigy80 points
    Dear Thomas,
                            Thank you very much for the PPT. The circuits & explanations are teach me a lot about DAS/ECG. But the presentation doesn't show me a real output of the ECG waveform from your circuit.  I hope the output will be very good and noise free. There is no EVM to purchase. So please do not close the conversation, i will come back with my result.
    Thank you
    Udhay
    Report Abuse
    • Reply
  • Thomas Kuehl
    on Jun 12 2012 10:33 AM
    Hello Udhay,
    The PowerPoint is intended to provide basic ECG concepts and some circuit ideas behind constructing a ECG demo circuit. The demo circuit is capable of producing an ECG output that can be displayed on a common DSO. When the session was presented in the past an audience volunteer would be used to observe their ECG waveform. We always had them clean their hands first with a pre-moistened wipe, allow their fingers to dry and then contact the PC board thumb/finger contacts as shown in the slides. The volunteer was seated and needed to be still while grasping the board during the measurement. Usually, it is not difficult to obtain a good, clean ECG waveform from voulnteer. I don't recall the exact DSO vertical volts per division setting, but I do think it was on the order of 50, or 100 mV/div.
    Some engineering will be required to get your ECG prototype going, but the circuits are straightforward and shouldn't be difficult to get working.
    Regards, Thomas
    Report Abuse
    • Reply
  • udhaya kumar a
    on Jun 14 2012 05:19 AM
    Prodigy80 points
    Dear Thomas,
    yes, the circuit in the powerpoint is to measure the heart beat not exactly for ECG waveform. Even thought if it is, i hope we can get some decent output waveform. Now i am having INA326 with me. Can i use OP07D opamp for testing purpose? For quick check i am going to design a single side home made PCB with INA326 & OP07D with some through hole component. Can i proceed with this OPAMP or not????
    regards
    Udhay
    Report Abuse
    • Reply
  • Thomas Kuehl
    on Jun 14 2012 12:30 PM
    Hi Udhay,
    I do not think the OP07D is a good choice to replace the RRIO CMOS operational amplifiers used in the DAS/ECG demo application. The OP07D is intended for a minimum supply of +/-3 V (6 V) and +/-15 V typical. The DAS/ECG amplifiers are powered are all powered by a single +5 V supply that appears after the input regulator. Also, the OP07D common-mode input and output swing ranges are much restricted relative to the power supply rails when compared to what is achievable with the recommended RRIO CMOS amplifiers. That may result in limited performance even if you were to increase the OP07D supply voltage to the minimum.
    I am not certain what capabilites are provided by TI in your country, but  in many countries free product samples are often available through the TI web site.
    Regards, Thomas
    Report Abuse
    • Reply
  • Govind M
    Posted by Govind M
    on Jun 26 2012 05:51 AM
    Prodigy80 points
    Hi Thomas,
    I am also working on a dry contact ECG system and would appreciate your help. Currently we have a biopotential amplifier circuit using discrete components and INA333 and OPA2333 that works well with leads placed on the chest, but not well with thumb leads. Although, a readable signal is possible.
    To get a better signal and/or to reduce the component count, I am evaluating ADS1298and I have the ADS1298ECG-FE evaluation board with me. I get good results with an ECG simulator, but now when I test with my thumbs the signal is worse than our discrete circuit and also has a very strong baseline drift. Do you have any guidelines for finger leads with ADS1298? I am directly feeding the finger signals captured from an electrode to ADS1298, should I be doing some pre-processing?
    I would also be interested in the dry contact circuit you have mentioned above, could you send me a copy of the presentation too? My email address is - govind at reka dot net.
    Thanks in advance!
    Govind
    finger ecg ADS1298
    Report Abuse
    • Reply
  • Thomas Kuehl
    on Jun 26 2012 11:06 AM
    Hello Govind,
    I will forward the DAS/ECG PowerPoint to the email address you provided. Also, I have contacted our data converter applications team to assist you with your questions regarding the ADS1298.
    Regards, Thomas
    Report Abuse
    • Reply
  • Aung Thiha
    Posted by Aung Thiha
    on Jul 03 2012 06:09 AM
    Prodigy10 points
    Hi Thomas,
    I am experimenting right foot feedback circuit from Webster's Medical Instrumentation book.
    I would be very appreciate if you can send me the above mentioned circuit.  My email is [lionel.thiha @live.com]. thanks.
    Report Abuse
    • Reply
  • Thomas Kuehl
    on Jul 03 2012 10:04 AM
    Hi Aung,
    I will send the DAS/ECG PowerPoint file to the email address you have provided.
    Best regards, Thomas
    Report Abuse
    • Reply
  • Nelson Migliacci
    Posted by Nelson Migliacci
    on Jul 11 2012 19:01 PM
    Prodigy10 points
    Hi Thomas,
    I'm working with an eye movement detector and I guess it will be helpfull to take a look to the powerpoint you've mentioned.
    I already built one with discrete Op. Amp. but now I'm looking for better performance, less consume and reduced size so I'm trying to find the better Inst. Amp. which fits with my requirements.
    My email address is nelsonmigliacci@hotmail.com.
    Thanks in advance!
    Nelson
    Report Abuse
    • Reply
123
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
