• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Amplifiers » Precision Amplifiers » Precision Amplifiers Forum » Transimpedance amplifier
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
The Signal blog
  • $core_v2_blog.Current.Name
    Pop Quiz!
    Posted 2 days ago
    by Bruce Trump
    Put away your books and take out a sheet of paper. Each question...
    Settling Time
    Posted 8 days ago
    by Bruce Trump
    Settling time is the time required for an op amp to respond to...
    Slew Rate—the op amp speed limit
    Posted 16 days ago
    by Bruce Trump
    Slewing behavior of op amps is often misunderstood. It’s...
This question is answered
Nisha Joshy
Posted by Nisha Joshy
on Jun 29 2012 06:07 AM
Prodigy160 points
I am doing a project using photodiode. I need to design the transimpednce amplifier for the photodiode current signal. The TIA should have a gain greater than 10^7 V/A and bandwidth greater than 12 KHz. Could you please recommend a product suitable for my application
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Bruce Trump
    Posted by Bruce Trump
    on Jun 29 2012 06:56 AM
    Mastermind21575 points
    Nisha,
    A critical factor in the selection of an op amp is the capacitance of the photodiode. Also, do you have any special power supply requirements?
    Regards, Bruce.
    TIA transimpedance op amp selection photodiode capacitance
    Report Abuse
    • Reply
  • Nisha Joshy
    on Jun 29 2012 08:37 AM
    Prodigy160 points
    Hi Bruce,
    Thanks for the reply. The capacitance of photodiode is 75pF. I would prefer a single supply voltage.
    Nisha
    Report Abuse
    • Reply
  • Bruce Trump
    on Jun 29 2012 14:29 PM
    Verified Answer
    Verified by Nisha Joshy
    Nisha,
    Operating from a single 5V supply, I would recommend the OPA376. This is a CMOS op amp with quite low noise. This is important in your situation because of the very large photodiode capacitance. The ratio of photodiode capacitance to feedback capacitance is high, which amplifies the voltage noise of the op amp. Thus a low noise op amp is important. I recommend a feedback capacitor of approximately 1pF in parallel with the 10M feedback resistor. Mount these feedback components in a manner to avoid stray capacitance to ground.
    Regards, Bruce.
    Report Abuse
    • Reply
  • Nisha Joshy
    on Aug 06 2012 08:50 AM
    Prodigy160 points
    Dear Bruce,
    Thanks for the reply. I checked OPA376 and it looks like I can achieve the gain of 10^7 with this but not a higher bandwidth .I can compromise on gain but not on bandwidth as I need the higher order harmonics of the signal. I also saw some more products like OPA380 & OPA657. OPA657 has much more lower noise but its dual supply . Can I use it in single supply configuration?
    Thanks in advance,
    Nisha
    Report Abuse
    • Reply
  • Bruce Trump
    on Aug 06 2012 10:58 AM
    Verified Answer
    Nisha,
    In a quick simulation, I think you can get 12kHz, -3dB bandwidth with the OPA376 using about 1.5pF feedback capacitance // 10M-ohm. I have assumed that you would bias the non-inverting input up to some positive mid-supply voltage on a 5V supply. Output would be referenced to this mid-supply voltage.
    The OPA380 could be used in a similar manner and would have plenty of bandwidth. It is also capable of a ground-referenced output using a pull-down resistor to a negative supply voltage. It appears, however, that you want to avoid a negative supply.
    The OPA657 has a very limited common-mode range and appears to really need a +/-5V supply with a ground-referred non-inverting input. Alternatively, it could be used on a 10V supply with the non-inverting input biased to 5V. This product is supported on the  "high speed amplifier" forum--the place to go if you have further questions on this device.
    Regards, Bruce.
    Report Abuse
    • Reply
  • Nisha Joshy
    on Aug 10 2012 03:37 AM
    Prodigy160 points
    Hi Bruce,
    I am using OPA380 in the single supply configuration, The noninverting input is biased at 2.5 V. But with 1.5pF capacitor , the output is oscillating at a very high frequency. What is the optimal value of capacitor to prevent this? I don't need a ground referenced output. Right now I am using a voltage source of 1V with 10 Mohm series resistor as the current source.
    Nisha
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
