• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Amplifiers » Precision Amplifiers » Precision Amplifiers Forum » PGA309 ADC Conversion Time
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
The Signal blog
  • $core_v2_blog.Current.Name
    Handy Gadgets and Resistor Divider Calculations
    Posted 7 days ago
    by Bruce Trump
    Handy gadgets make our engineering life easier—the little...
    Chopper Op Amps—are they really noisy?
    Posted 14 days ago
    by Bruce Trump
    Chopper op amps offer very low offset voltage and dramatically...
    Bypass Capacitors… yes, but why?
    Posted 27 days ago
    by Bruce Trump
    Everyone knows that op amps should have power supply bypass capacitors...
This question is answered
Walt Rogers
Posted by Walt Rogers
on Jul 01 2012 03:55 AM
Prodigy40 points
I am observing ADC conversion times that seem significantly longer than specified in the data sheet:
Vsupply and ref are 5 V
TEST pin = high
Conversions are started and queried via I2C at 400 kHz
CEN = 0 (Noncontinuous Conversion mode)
TEN = 0 (External Signal Mode)
AREN = 0 (use external ADC reference)
Measured [specified]  conversion time for ADC2X = 0 (1x conversion speed):
11 bits: 8.7 ms [6]
13 bits: 34 ms [24]
14 bits: 67 ms [50]
15 bits: 133 ms [100]
Measured [specified]  conversion time for ADC2X = 1 (2x conversion speed):
11 bits: 4.5 ms [3]
13 bits: 17 ms [12]
14 bits: 34 ms [25]
15 bits: 67 ms [50]
I understand that the specifications in the data sheet are typical, but the observed conversion times  seem quite far off.
Are the observed conversion times reasonable? If so, what am I missing when I look at the data sheet?
Can you specify the conversion times more than what the data sheet offers (e.g. min/max)?
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Chris Featherstone
    Posted by Chris Featherstone
    on Jul 02 2012 19:52 PM
    Expert5125 points
    Walt,
    We are currently looking into this and will get back to you shortly.
    Chris Featherstone
    Linear Characterization Engineer
    High Performance Linear Products
    Report Abuse
    • Reply
  • Ian Williams
    Posted by Ian Williams
    on Jul 03 2012 12:07 PM
    Genius14235 points
    Hello Walt,
    I believe the extra time you're observing is the PGA309 reading from the EEPROM lookup table before sending out data. I'm out of the office today, and tomorrow is a holiday, but I will take some measurements on Thursday and let you know what I find.
    EDIT: The time for the PGA309 to read the lookup table is on the order of microseconds so it shouldn't affect the time that much. In any case I'll let you know my measurement results on Thursday.
    Ian Williams
    Linear Applications Engineer
    High Performance Linear and Sensing Products
    Report Abuse
    • Reply
  • Ian Williams
    on Jul 06 2012 13:24 PM
    Genius14235 points
    PGA309 Temp ADC Conversion Time Test.pdf
    Hello Walt,
    My test results are uploaded as an attached .pdf file. The conversion times I measured were as fast or faster than the typical times specified in the PGA309 User's Guide. These times are trimmed at final test so this is the expected result.
    I know that your test method differed slightly as you were triggering single-shot conversions, but I feel that my method is a better indication of the conversion time in normal operation.
    Ian Williams
    Report Abuse
    • Reply
  • Walt Rogers
    on Jul 06 2012 14:49 PM
    Prodigy40 points
    Hi Ian,
    Thank you for clarifying where the datasheet specs come from.
    Can you offer specifications of end-to-end conversion times for single-shot external control (TEST pin high, I2C request/query, same conditions as in original post)? Specifically, how long is the ADCS high after it is set via a register write? If they are significantly longer than the typical specification, can you explain why, so I may better understand the chip's operation?
    As you probably have guessed of similar, here is the code I used in the tests in my original post :
         while (1)
           PGA309_WriteRegister(6, 0x30A0);  // Start conversion via I2C
            do
                status = PGA309_ReadRegister(6);  // Get conversion status via I2C
            } while ((status & (1<<12)) != 0);
    I can send scope screen shots if you would like.
    I have found that controlling the PGA309 (TEST pin high) by an external microcontroller and reading Vout via the Temp ADC to be very useful. My application is a closed-loop motor controller where I want a fixed feedback sample rate, but does not require sensor temperature compensation. I use single-shot ADC mode to ensure that sample rate, which is on the same order as the ADC speed.
    Is there a method to synchronize my servo to the PGA309 ADC conversions in continuous mode?.
    Report Abuse
    • Reply
  • Ian Williams
    on Jul 11 2012 18:52 PM
    Genius14235 points
    Hello Walt,
    I would like to see the screenshots of this activity. I will check with the digital designer of the PGA309 to see if there's a difference in the end-to-end conversion time in this situation.
    Ian Williams
    Report Abuse
    • Reply
  • Walt Rogers
    on Jul 12 2012 00:58 AM
    Prodigy40 points
    Hi Ian,
    I have attached a file that contains scope screen shots for 11- and 13-bit ADC resolutions in turbo mode, which, I think adequately represent other resolutions and non-turbo mode.
    Perhaps other users of the PGA309 Test mode will find the results of your inquiry useful.
    Walt Rogers
    6403.PGA309 Test mode conversion times.pdf
    Report Abuse
    • Reply
  • Ian Williams
    on Jul 18 2012 16:16 PM
    Verified Answer
    Verified by Walt Rogers
    Genius14235 points
    Hello Walt,
    I've conferred with the PGA309 designers on this topic. Their input is that there's some internal "housekeeping" which happens in I2C slave mode, both at the beginning and end of communication, that makes the conversion seem longer. There is also some post-processing required to change the state of the ADCS bit, adding some extra time as well.
    Unfortunately there is no way to re-simulate this behavior as the design databases are very old and no longer supported in our systems, so we could not give you more exact numbers on what the maximum "end-to-end" conversion time will be. However, based on your observations I feel that adding 50% to the data sheet spec would give a fairly accurate maximum time.
    Ian Williams
    Report Abuse
    • Reply
  • Walt Rogers
    on Jul 19 2012 00:30 AM
    Prodigy40 points
    Hi Ian,
    Thank you for your investigation and report.
    In case you guys have a lot of free time on your hands, perhaps the slave processing time overhead could be mentioned in the datasheet or PGA309 Microcontroller Application document.
    The conversion times I have seen are rock solid and easy to measure, so at least it looks like I have something I can depend on.
    Thanks to TI for providing such a useful and flexible chip.
    Walt Rogers
    Report Abuse
    • Reply
  • Ian Williams
    on Jul 19 2012 11:51 AM
    Genius14235 points
    Hello Walt,
    You're welcome. Thank you for your patience while I dug into this issue.
    I agree that it would be useful to expand on the PGA309 documentation to account for this overhead. Your measurements will be helpful in determining how repeatable the I2C initiated, end-to-end conversion times are across devices. Based on my discussion with the designers and what you have reported, I believe that these will be very uniform.
    I wish you all the best in your designs with the PGA309.
    Ian Williams
    PGA309
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
