• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Amplifiers » Precision Amplifiers » Precision Amplifiers Forum » OPA140 Input Current Noise Density
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
The Signal blog
  • $core_v2_blog.Current.Name
    Pop Quiz!
    Posted 1 day ago
    by Bruce Trump
    Put away your books and take out a sheet of paper. Each question...
    Settling Time
    Posted 7 days ago
    by Bruce Trump
    Settling time is the time required for an op amp to respond to...
    Slew Rate—the op amp speed limit
    Posted 14 days ago
    by Bruce Trump
    Slewing behavior of op amps is often misunderstood. It’s...
This question is not answered
Hassan Kelley
Posted by Hassan Kelley
on Jul 20 2012 10:27 AM
Prodigy80 points
What is the corner frequency of the input current noise density for the OPA140?  The wide band input current noise density for the OPA140 is listed as 0.8 fA/rt-Hz at 1kHz but I work down in the instrumentation band where 1/f noise is the killer.  Are there any plots for the input noise current density?
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Bruce Trump
    Posted by Bruce Trump
    on Jul 22 2012 07:38 AM
    Mastermind21545 points
    Hassan,
    I don't believe that much is known about the possible flicker region of current noise on the OPA140. It is extremely difficult to isolate and measure current noise of a low input bias current FET amplifier. We generally resort to shot noise calculations to estimate current noise of these amplifiers. The numbers that this produces usually rule out current noise as a significant contributor in commonly used circuit configurations.
    Can you provide information on your circuit configuration or application? With some details, we can determine whether current noise is likely to be an issue.
    Regards, Bruce.
    OPA140 current noise 1/f flicker
    Report Abuse
    • Reply
  • Hassan Kelley
    on Jul 26 2012 06:10 AM
    Prodigy80 points
    I'm using the OPA2140 in two locations.  The first location uses the OPA2140 in a 1/3 Hz unity gain Sallen Key low pass butterworth anti-aliasing filter that drives a 24 bit ADC.  The two resistors in series with the non-inverting input of the filter amplifier are both 309 kOhms.  I'm concerned about this large resistance interacting with the noise current of the OPA2140.  The feedback capacitor is 2.2 uF and the shunt capacitance is 1.1 uF.
    The second location of the OPA2140 is in the "I" and "D" amps of a PID of a null balance up stream of the anti-aliasing filter described earlier.  The "I" term amp as a series resistance of 100 kOhms and a feedback (integrating) capacitance of 6.8 uF.  The "D" term amp has a series resistances of 75 kOhms in series with 0.22 uF and a feedback capacitance of 75 kOhms in parallel with 0.22 uF.
    I am also concerned about the noise generated in these two terms but particularly the "D" term since it is notoriously sensitive to noise.
    I'm currently getting around 22 out of 24 bits.  Should I be quiet and happy?
    Report Abuse
    • Reply
  • Bruce Trump
    on Jul 26 2012 13:16 PM
    Hassan,
    I think it is very unlikely that current noise will be a significant contributor in any of these cases. Noise in the D term will, of course, tend to emphasize high frequency noise.
    You have not indicated the nature of your control system. What are you measuring? The sensor or input signal may be a major source of noise. It may be instructive to measure the output noise of the PID system with sensor input and with shorted input to see how they compare.
    Regards, Bruce.
    Report Abuse
    • Reply
  • Hassan Kelley
    on Aug 31 2012 07:57 AM
    Prodigy80 points
    You have answered my noise questions but now I have a rail to rail question.
    How well will the OPA2140AID drive the input to a delta-sigma ADC through a 299 Ohm-1uF  RC filter?
    The equivalent input structure of the ADC (LTC2440) is a 500 Ohm series resistor and a 5pF sampling capacitor.
    I suspect the rail-to-rail nature of the op-amps output stage will struggle with this small resistive load but I want your knowledgeable input.
    --hassan
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
