• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Amplifiers » Precision Amplifiers » Precision Amplifiers Forum » LMP7721 Common mode (CM) and differential (DM) input capacitance values
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
The Signal blog
  • $core_v2_blog.Current.Name
    Handy Gadgets and Resistor Divider Calculations
    Posted 5 days ago
    by Bruce Trump
    Handy gadgets make our engineering life easier—the little...
    Chopper Op Amps—are they really noisy?
    Posted 12 days ago
    by Bruce Trump
    Chopper op amps offer very low offset voltage and dramatically...
    Bypass Capacitors… yes, but why?
    Posted 25 days ago
    by Bruce Trump
    Everyone knows that op amps should have power supply bypass capacitors...
This question is answered
Tom Campbell1
Posted by Tom Campbell1
on Aug 02 2012 11:56 AM
Prodigy60 points
My application is a low noise charge amp.  Thus, knowing the CM and DM input capacitances is important for predicting the white input referred voltage noise density.  Unfortunately, the datasheet for this device does not list values for these parameters.  So, to see if the model included them, I ran simulations of the input capacitance measurement circuits shown in Figure 8.8 on page 97 of Bob Pease's book Troubleshooting Analog Circuits.  The values I obtained were so improbably small that I concluded that they weren't part of the model either.  Has anyone characterized them?
input capacitance charge amp noise
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Paul Grohe
    Posted by Paul Grohe
    on Aug 03 2012 18:39 PM
    Verified Answer
    Verified by Tom Campbell1
    Expert4265 points
    Hi Tom,
    The LMP7721 is based on the LMP7711 core. The LMP7711 datasheet has a Cin graph in the apps section of the datasheet.
    Because the 7721 has the bootstrapped ESD diodes (the reason for the low input bias), the input capacitance will be about 2-3pF less than the LMP7711.
    The 7721's common mode input capacitance is about 11pF at mid VCM under feedback (minimal Cdm contribution). It is high because the input stage is low noise input stage, which requires greater gate area. I don't recall the Cdm numbers...but I would guess around 2-3pF (again, because of the large input area).
    A quick way to measure the total input capacitance is to set the LMP7721 up as a follower (output to inverting input) and use a large input resistor (100K to 1Meg) in series with the non-inverting input. This large resistor will form a RC pole with the input capacitance.
    A signal of 1KHz to 100KHz is then sourced through the series resistor to find the RC pole, which can then be used to calculate Cin against the known series resistor.
    The trick is to use a large resistor, 100K to 1Megohm, with a very low parallel capacitance. A typical 1/4 watt resistor has 0.3pF across it - which can interfere with this measurement. The solution is to place several resistors in series to add up to the desired resistance. Five resistors in series, floating in the air, will have around 0.06pF of parallel capacitance.
    Here is how you do it:
    I start with a resistor value of about 1Mohm (five 200K's in series) from the generator output directly to the positive input.
    Set the generator to 1KHz, 100mVpp sine wave. Apply the generator directly to the non-inverting input (easily done by temporarily shorting out the resistor). Monitor the DUT output with a scope or AC DMM. The DUT output should be 100mVpp. This is the "reference" reading.
    Remove the short from the resistor and slowly sweep the generators frequency up until the DUT output level drops to 70.7mVpp (0.707 * reference level) and note the generator frequency. For the 7721, using a 1MEG resistor, this should be around 15KHz.
    With the known frequency and resistor values, you can calculate C from the standard RC formula. Note that this C value includes Ccm, Cdm, trace and fixture capacitance (the total capacitance at the non-inverting input). Solder the resistor directly to the input lead, lifted into the air, for most accurate results.
    Hope this helps...
    Paul Grohe
    Integrated Signal Chain Applications, SVA
    Report Abuse
    • Reply
  • Tom Campbell1
    on Aug 13 2012 12:34 PM
    Prodigy60 points
    Paul,
    Thank you.  Just for clarity's sake, and given that my Vs = +/- 2.5V, you would estimate the 7721's common mode input capacitance to be "about 11pF at mid VCM under feedback (minimal Cdm contribution)."  I take it that this value is from either input to ground.  Am I correct?
    Tom
    input capacitance LMP7721 charge amplifier LMP7711
    Report Abuse
    • Reply
  • Paul Grohe
    on Aug 13 2012 12:49 PM
    Verified Answer
    Expert4265 points
    HI Tom,
    Yes. From either input to ground. Each input will be ~11pF to ground. Where (AC) "Ground" is considered the mid-point of the supplies.
    Paul Grohe
    Report Abuse
    • Reply
  • Tom Campbell1
    on Aug 14 2012 08:11 AM
    Prodigy60 points
    Paul,
    Thanks for your clarification.  On last question, do you have Ccm and Cdm values for the LM6211?
    Tom
    common mode and differential mode input capacitance
    Report Abuse
    • Reply
  • Paul Grohe
    on Aug 14 2012 11:00 AM
    Expert4265 points
    HI Tom,
    There is a input capacitance vs common mode voltage plot on page 11 of the datasheet, and it is mentioned as 5.5pF in the front page text.
    Ccm looks to be about 5.5 to 6pF. I did not see any data for Cdm.
    This device was designed for PLL filters - so the 1/f noise is fairly low for a fast CMOS device. This also means larger gate area, too. But not by much.
    Also see the LMH6601 or OPA355 CMOS if you need speed (250MHz) and low input capacitance (<2pF). Though because it is not optimized for noise and it is a high-speed device, the 1/f and noise is fairly high.
    Paul Grohe
    Report Abuse
    • Reply
  • Tom Campbell1
    on Aug 15 2012 07:56 AM
    Prodigy60 points
    Paul,
    I just found the common mode capacitance vs. common mode voltage graph for the 6211.  For my application, it looks like it'll be about 7pf.  Is the front-end's topology similar to that of the LMP7711 so that I can I safely use 2-3pf for the differential mode capacitance?
    Tom
    LM6211 input capacitance
    Report Abuse
    • Reply
  • Paul Grohe
    on Aug 15 2012 10:58 AM
    Expert4265 points
    Hi Tom,
    No, the 7211 and 6211 are completely different animals. To get the 24V supply, the 6211 is built on a different process and also has a bootstrapped CMOS front end, so they are not exactly the same. But they may be similar as far as strays - so 2-3pF would probably be in the ball park.
    Paul Grohe
    Report Abuse
    • Reply
  • Tom Campbell1
    on Aug 16 2012 14:17 PM
    Verified Answer
    Prodigy60 points
    Thank you.
    Tom
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
