• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Amplifiers » Precision Amplifiers » Precision Amplifiers Forum » INA116 input protection
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
The Signal blog
  • $core_v2_blog.Current.Name
    Handy Gadgets and Resistor Divider Calculations
    Posted 5 days ago
    by Bruce Trump
    Handy gadgets make our engineering life easier—the little...
    Chopper Op Amps—are they really noisy?
    Posted 13 days ago
    by Bruce Trump
    Chopper op amps offer very low offset voltage and dramatically...
    Bypass Capacitors… yes, but why?
    Posted 26 days ago
    by Bruce Trump
    Everyone knows that op amps should have power supply bypass capacitors...
This question is not answered
Vladimir Dudko
Posted by Vladimir Dudko
on Aug 03 2012 01:33 AM
Prodigy30 points
I am developing an amplifier for recording the electrical activity of cells. As a pre-amplifier INA116 set (differential inclusion of inputs). What kind of protection circuit inputs can be used? What kind of protection scheme is made in the INA116 inputs? Can I just put in series with each input resistor (eg 1k)?
Vlad
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Pete Semig
    Posted by Pete Semig
    on Aug 03 2012 18:13 PM
    Genius13115 points
    Hello Vlad,
    I have a few quick questions about your application.  What type of 'cells' are you referring to?  Also, what is the frequency and amplitude of the transients that you expect to see on the inputs of the INA116?  What is the source of the transients?  Finally, please share your schematic if you can.
    Pete Semig
    Precision Analog Applications
    Report Abuse
    • Reply
  • Vladimir Dudko
    on Aug 06 2012 02:31 AM
    Prodigy30 points
    We study the snail cells. The electrical activity of the cells expressed the pulses of positive polarity in the presence of a constant negative bias (cell potential). The amplitude of the pulses to 10 mV, a constant offset to 80mV, pulse duration (3-20) ms. Since the operator manipulates the microelectrodes when connected to a cell, there is the possibility of accumulation and electrostatic charge. How to protect a preamplifier??
    Report Abuse
    • Reply
  • Vladimir Dudko
    on Aug 06 2012 03:29 AM
    Prodigy30 points
    Can I use this feature to protect .... http://www.bourns.com/pdfs/MLU.pdf
    Report Abuse
    • Reply
  • Pete Semig
    on Aug 06 2012 14:58 PM
    Genius13115 points
    Hello Vlad,
    Thanks for the additional information.  I am looking into this further and will get back with you as soon as I can.
    Pete Semig
    Report Abuse
    • Reply
  • Pete Semig
    on Aug 07 2012 13:47 PM
    Genius13115 points
    Hello Vlad,
    You can use the aforementioned varistor, but please note that the leakage current is 5nA.  This is much greater than the input bias current of the INA116 and will therefore cause additional error.
    Pete Semig
    Report Abuse
    • Reply
  • Bruce Trump
    Posted by Bruce Trump
    on Aug 07 2012 14:07 PM
    Mastermind20715 points
    Vlad,
    I assume that you chose the INA116 for its extremely low input bias current to avoid current flowing in the cell. As Pete points out, these protection devices are notoriously leaky.
    I suggest that you protect with 10k-ohm resistors in series with each input and 47pF capacitor at each input terminal of the INA116 to ground. This will add a high degree of immunity from ESD. If you then use reasonable precautions to minimize ESD you should have no problem.
    Regards, Bruce.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
