• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Amplifiers » Precision Amplifiers » Precision Amplifiers Forum » INA201, INA201-Q1
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
The Signal blog
  • $core_v2_blog.Current.Name
    Grounding Principles
    Posted 4 days ago
    by Bruce Trump
    In a previous blog on supply bypassing , I cautioned that poor...
    Handy Gadgets and Resistor Divider Calculations
    Posted 11 days ago
    by Bruce Trump
    Handy gadgets make our engineering life easier—the little...
    Chopper Op Amps—are they really noisy?
    Posted 19 days ago
    by Bruce Trump
    Chopper op amps offer very low offset voltage and dramatically...
INA201, INA201-Q1
INA201, INA201-Q1
This question has suggested answer(s)
giorgio costa
Posted by giorgio costa
on Aug 03 2012 08:42 AM
Prodigy60 points
if the voltage supply Vs is over 15V in many devices I can't reset the latch comparator or if I send a reset pulse the device goes in fault and is not possible to reset
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Justin B.
    Posted by Justin B.
    on Aug 03 2012 09:47 AM
    Intellectual1960 points
    Hi Giorgio,
    Could you be a bit more specific about what product group you are using so that I can make sure your question is placed in the correct forum? This way you will get a response sooner rather than later. Thanks!
    Justin
    E2E Community Moderator, Texas Instruments
    Report Abuse
    • Reply
  • giorgio costa
    on Aug 27 2012 03:16 AM
    Prodigy60 points
    I think that the product group  is Precision Amplifiers
    Report Abuse
    • Reply
  • Pete Semig
    Posted by Pete Semig
    on Aug 28 2012 09:41 AM
    Genius13215 points
    Hello Giorgio,
    Can you please provide us with a schematic?
    Pete Semig
    Precision Analog Applications
    Report Abuse
    • Reply
  • giorgio costa
    on Aug 28 2012 10:03 AM
    Prodigy60 points
    Hello Pete,
    following the schematics.
    I use about 43 blocks like this and the problem comes if the "V13" that supply the INA201 is over 14,8 -15 V. About  the half of the INA201 comparator output is pulled down to gnd also if the input voltage of the comparator is 0 (less then 0.6V of the ref).  It's possible that the internal Vref go wrong. When I reset the INA201 comparator the output ( pin6 )   in some device toggles gnd - pull up.
     2350.Schematic Prints.pdf
    Report Abuse
    • Reply
  • Pete Semig
    on Aug 28 2012 16:45 PM
    Genius13215 points
    Hello Giorgio,
    Thanks for the schematic.
    It appears as though the output voltage is heavily divided down.  Can you please help me understand your typical use case?  For example, I see the shunt is 3mohms.  In order to meet the 20mV shunt voltage requirement for linear operation, your minimum current must be 6.7A.  The output can swing to 12.75V with a 13V supply, therefore your maximum load current is 85A.  Correct?  Also, what is the impedance of I_J4_OUT_20A_HS_1?
    I see a differential filter on the input using 100ohm resistors.  Please note that we recommend making these as small as possible.  The cutoff frequency of the input filter is set to ~8kHz, so you could reduce the resistors to 10ohms and increase the capacitor to 1uF.
    There is also a 470pF cap on pin 3 of the device (the comparator input).  What is this for?
    Pete Semig
    Report Abuse
    • Reply
  • giorgio costa
    on Aug 29 2012 02:50 AM
    Prodigy60 points
    Hello Pete,
    Thanks for your support,
    The typical use is for 24V automotive output switch. I have different current range from 2A  to 20A. I need to monitor the current but also protect the MOS from max overcurrent. The load are different :  lamp, DC motor, valve and many of these have a peak current at switch on ( inrush current  when there are input capacitor or cold lamp). So to avoid the max load current at switch ON I need to increase the voltage supply and over 15V I have this surprise. Many INA201 output comparator don't follow the logical input signal and also after the reset pulse don't respect the specification.
    About the differential filter I don't use it and the 100nF capacitor is not installed, there are the 100Ohm in series with sense input but I can remove. The 470pF on pin 3 is for a short delay but also this can be removed.
    Report Abuse
    • Reply
  • Pete Semig
    on Aug 29 2012 14:28 PM
    Suggested Answer
    Genius13215 points
    Hello Giorgio,
    Thanks for the additional information.
    I have tried to recreate your issue with the comparator in my lab but have not succeeded.  The device was supplied with 13V and the comparator output pulls up to 5V through a 4.7kohm resistor.  The comparator output behaves as I would expect.
    I then changed the supply voltage to 18V, and the comparator output behaves as I would expect.
    Therefore, perhaps there's a misunderstanding with respect to the comparator behavior.  Please note the comparator output is latched.  When pin 5 is low, the latch is transparent.  When pin 5 is high, the output is latched and will not change if the input goes low.  Pin 5 must go low to change the output.  This behavior is shown in Figure 30 of the datasheet.
    I hope this helps.
    Pete Semig
    Report Abuse
    • Reply
  • giorgio costa
    on Aug 30 2012 03:55 AM
    Prodigy60 points
    Hi Pete,
    the problem comes out on about half of the device that I have so it's possible that the INA201 you are testing is ok.
    The use of the pin 5 is clear, I use it to latch the comparator. The strange thing if I increase the supply voltage over 15V and I give some rest pulse on pin 5 the comparator output toggles up and down with input = 0.
    One question, do you think  possible that the components are not original TI but a bad copy ??? I buy them from official supplier but in the past with other component I have this surprise
    thanks
    Report Abuse
    • Reply
  • Pete Semig
    on Aug 30 2012 08:05 AM
    Genius13215 points
    Hello Giorgio,
    A couple of quick questions:
    1)  Have you tried swapping devices from a functional circuit to a non-functional circuit?  In other words, does this behavior follow the device or the circuit?
    2)  Have you removed one of the 'bad' devices from your circuit and verified this behavior independent of the application?  If so, please send me a schematic of your test circuit.
    Please note that when I ran my tests, I did not use the current shunt portion of the INA201.  I was under the impression that the issue revolved around the supply voltage and comparator.  In order to isolate the comparator, please disconnect the current shunt from the comparator by removing the 56kohm, 4.7kohm, and 470pF passives.  Then apply a voltage to the test point connected to pin 3 of the INA201 and monitor pin 6.  I would connect pin 5 to ground and verify transparent operation of the comparator.  Do this for both Vs=13 and Vs>=15.  Please let me know the results.
    Pete Semig
    Report Abuse
    • Reply
  • giorgio costa
    on Aug 31 2012 06:49 AM
    Suggested Answer
    Prodigy60 points
    Hello Pete,
    I go on with my test, and finally I find the problem. I see that the problem come from the reset pulse front. I drive the reset signal with an SN74LVC1G17 and the signal front are very quick. I have added a capacitor (47nF) on the reset signal to smooth the front and the problem disappear. So is the rise front of the reset signal that in some way affect the comparator. During the test I have shorted the comparator input to 0V.
    Probably you can recreate the same situation on your bench test to confirm the criticity
    Report Abuse
    • Reply
  • Pete Semig
    on Aug 31 2012 09:01 AM
    Genius13215 points
    Hi Giorgio,
    Thanks for the feedback...it is good to hear your problem has been resolved.
    Pete Semig
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
