• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Amplifiers » Precision Amplifiers » Precision Amplifiers Forum » OP AMP Current Noise
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
The Signal blog
  • $core_v2_blog.Current.Name
    Pop Quiz!
    Posted 1 day ago
    by Bruce Trump
    Put away your books and take out a sheet of paper. Each question...
    Settling Time
    Posted 7 days ago
    by Bruce Trump
    Settling time is the time required for an op amp to respond to...
    Slew Rate—the op amp speed limit
    Posted 15 days ago
    by Bruce Trump
    Slewing behavior of op amps is often misunderstood. It’s...
This question is not answered
Frank Huang16969
Posted by Frank Huang16969
on Dec 29 2009 03:17 AM
Prodigy160 points
Hi, I have 2 questions about the current noise difference between BJT OPA & FET/CMOS OPA:
1.  When looking at OPA134/300 and other FET/CMOS OPA's current noise density, it seems has a inverse noise shape with voltage noise... i mean the higher the bandwidth cause higher current noise (I call it white noise then f noise...).  Why?
2. FET/CMOS OPA's current noise shape is different from Bipolar OPAs such as OPA277, the BJT OPA's noise and current noise density has the same shape(1/f noise then white noise). Why BJT's current noise has the same shape with voltage noise?
Thanks a lot for your reply.
        Frank
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Art Kay
    Posted by Art Kay
    on Dec 29 2009 10:21 AM
    Expert3225 points
    f-squared noise.pdf
    Frank,
    The increase in noise is called f-squared noise.  This noise is the result of an interaction of the input voltage noise and the input capacitive reactance.  I have an attached a preliminary article on this subject.  This article has not been published.  I have published a series of articles on noise on en-genius (see link below).
    http://www.en-genius.net/site/zones/audiovideoZONE/technical_notes/avt_120108
    Art Kay Senior Applications Engineer High Performance Linear
    noise
    Report Abuse
    • Reply
  • Frank Huang16969
    on Dec 29 2009 20:10 PM
    Prodigy160 points
    Current Noise Difference.doc
    Art,
    I am so honored to have you answered my question. Actually, your series of articles about OPA Noise have been translated into Chinese, I have studied #1-#7 already. Thanks for introducing #8 and the latest one. I will try to understand the f squared noise from your articles. I will reply you when I have further questions.
    BTW, I have added an Word file to describe my question more clear to other visitors.
    Thanks again!
    B. Regards,
    Frank Huang
    Report Abuse
    • Reply
  • Frank Huang16969
    on Dec 29 2009 23:31 PM
    Prodigy160 points
    Art,
    So, do you think the f-squared noise existing in all kinds of OPA? But some of them didn't mention it in their datasheet, such as OPA277, OPA211.
    B. Regards,
    Frank
    Report Abuse
    • Reply
  • Art Kay
    Posted by Art Kay
    on Dec 30 2009 06:37 AM
    Expert3225 points
    I’m glad you were able to make use of the articles.  Thanks for the feedback.
    Yes.  F-squared noise exists on all op-amps.  On bipolar amplifiers the magnitude of the broadband current noise is larger then the f-squared noise, so you can’t see the f-squared noise.  OPA211 and OPA277 are bipolar amplifiers.  In FET input amplifiers, the broadband current noise is smaller so you can see the f-squared noise in measurements and simulations.
    However, in new datasheets we do not show f-squared noise.  This is because f-squared noise is an interaction between voltage noise and the input captive reactance of the op-amp.  So, for example, if you were developing a spice model for the op-amp, the f-squared noise would automatically be generated by the input capacitance and the voltage noise.  We do not want people to erroneously count both f-squared noise in the current noise spectral density and f-squared noise from interaction with the voltage noise and input capacitance.  The only source of f-squared noise is from interaction with the voltage noise and input capacitance.
    A good tool to help understand f-squared noise is Tina.  Try running a few Tina simulations with and without input capacitance to see the f-squared effect.
    Report Abuse
    • Reply
  • Frank Huang16969
    on Dec 30 2009 19:39 PM
    Prodigy160 points
    Art,
    Yes, simulation and hands-on will give me more deep understanding on it. It's great to learn from you. Thanks a lot for your help!
    B. Regards,
    Frank
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
