OPA4344 / Uncontrolled operation
Other Parts Discussed in Thread: OPA4344
Hi All,
Our customer has evaluated OPA4344 at feedback circuit of AC/DC converter as attached. But the output of OPA4344 is uncontrolled suddenly though we have not found any trigger of this behavior. On the other hand, this behavior is fixed by adding RC filter on VCC of OPA4344.
Can you give your advice for the reason why this behavior is happened and it’s improved by adding RC filter on VCC?
Your quick response will be appreciated.
Sonoki / Japan disty
OPA4344 abnormal operation.pdf
  • Hi Sonoki,
    Did you try adding only a decoupling capacitor instead of an RC filter? Not using decoupling capacitors can give unexpected results. Please see http://e2e.ti.com/blogs_/b/precisiondesignshub/archive/2013/08/13/the-decoupling-capacitor-is-it-really-necessary.aspx
    Thank you,
    Tim Claycomb
  • Dear Tim-san,
    Thank you for introducing the article about importance of decoupling capacitor.
    Now I'd like to have your further comments for this circuit. The OUT and +IN are biased from VCC line, so I think it may negatively affect for operation if some spike noise is observed on VCC pin and there is only small decoupling capacitor. So what do you think about this?
    Sonoki
  • Hi Sonoki,
    Yes, it is possible to see any noise spikes on the output if they are present at +IN. To help minimize noise spikes on +IN, place a capacitor from +IN (pin 10) to ground. The decoupling capacitors are there to give the op amp a steady power supply, I would recommend using a 0.1uF in parallel with 100pF for decoupling capacitors.
    Thank you,
    Tim Claycomb
  • Tim-san,
    Thank you for your comment. I'll ask our customer to try to add capacitor on +IN and VCC.
    Sonoki
