• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Amplifiers » Precision Amplifiers » Precision Amplifiers Forum » photodiode transimpedance amp recommendation
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
The Signal blog
  • $core_v2_blog.Current.Name
    Pop Quiz!
    Posted 2 days ago
    by Bruce Trump
    Put away your books and take out a sheet of paper. Each question...
    Settling Time
    Posted 8 days ago
    by Bruce Trump
    Settling time is the time required for an op amp to respond to...
    Slew Rate—the op amp speed limit
    Posted 16 days ago
    by Bruce Trump
    Slewing behavior of op amps is often misunderstood. It’s...
This question is not answered
MJ16032
Posted by MJ16032
on Oct 22 2009 15:30 PM
Prodigy220 points
I am currently using a cmos single supply with 9 pA Ibias GBW 10Mhz low power battery powered app.  I would like to find something similar that uses dual supplies.  Do you have some recomendations for something that would work well given these requirements?
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Matt Hann
    Posted by Matt Hann
    on Oct 22 2009 20:34 PM
    Expert7120 points
    MJ,
    Most of TI's low power amplifiers fall under the single supply category.  What is your application, specific power supply rails, and quiescent power target?  Are you reverse-biasing the photodiode or operating it under a zero bias condition?
    Matt
    Report Abuse
    • Reply
  • MJ16032
    Posted by MJ16032
    on Oct 27 2009 12:10 PM
    Prodigy220 points
    Hi Matt,
    Thanks for the reply.   have not worked with op amps much so much of this is new to me.  I will be detecting signals with a si photodiode.  I have been testing some using  a single supply  with anode to non-inverting, cathode to inverting, a feedback to give gain and some feed back capacitance to compensate for stability.
    My main issue in using the single supply is that I am using multiple stages and using dc blocking capacitors in a couple of stages.  I am using a first gain stage to amplify the signal an amount without saturating.  This amplifies the DC, which i remove with a dc blocking capacitor.  I then have to add a certain amount of DC  back into the signal in order to keep it within operating rails to amplify in a the signal again in second stage.  If i do this in 2 stages I have to have extra circuitry to add a small amount of DC back into the signal in order to operate correctly with a single supply amp.
    It seem to me that that this could be simplified by using a dual supply amps.  The signal would remain within the operating rails after the DC blocking stages.  Would you recommend this approach?
    As I have not worked with opamps much, I am not too familiar with what dual supply are capable of in terms of quiescent current.   I would hope to keep it to a minimum.  The rails would be +/- 3V.  The main concern is to keep the ibias as low as possible.  Are there any dual supplies that are fabricated using cmos?
    Thanks for the help.
    Report Abuse
    • Reply
  • Matt Hann
    Posted by Matt Hann
    on Oct 27 2009 12:25 PM
    Expert7120 points
    MJ,
    Your transimpedance configuration is a pretty standard photovoltaic bias and the typical key concern out of this critical stage is SNR (signal to noise).  If you give me the SI photodiode you are using and your expected photodiode current range (i.e. 10nA to 10uA) I can recommend a single supply solution and a dual supply solution (including the gain stages).  Keep in mind that all of the single supply OPA devices have a MAX supply specification of 5.5V so you can actually run them off +/-2.75V.
    Do you have an ADC and a uC picked out for this application yet?  At what frequency are you pulsing your photodiode?
    Report Abuse
    • Reply
  • MJ16032
    Posted by MJ16032
    on Oct 27 2009 13:58 PM
    Prodigy220 points
    Hi Matt,
    I am looking at moving towards using a hamamatsu 6968-01 : http://sales.hamamatsu.com/index.php?id=13183125&language=1&undefined.  We will be using them at a maximum distance from the source, so the current will be minmal, somwhere above the dark current > 5nA.
    I am currently using a dsPIC.  I am not sure if I will need a seperate ADC.   The expected bandwidth is less than 100 khz.
    Thanks.
    Report Abuse
    • Reply
  • Matt Hann
    Posted by Matt Hann
    on Oct 27 2009 14:31 PM
    Expert7120 points
    MJ,
    What is your MAX swing range and levels that you will be feeding to your ADC?  (i.e. 0-5V, 0-3V, -2.5 to 2.5V, etc.)
    Report Abuse
    • Reply
  • MJ16032
    Posted by MJ16032
    on Oct 27 2009 16:12 PM
    Prodigy220 points
    Matt,
    At this stage I am not sure if i will be using an ADC.  I hope to simplify processing by using a schmitt trigger with the threshold being set by a pwm output of the micro.  I may need to look more closely at the analog data in the future and would likely need an ADC at this point.  This being the case I would only be looking at 0-3Volts.
    Report Abuse
    • Reply
  • Matt Hann
    Posted by Matt Hann
    on Oct 29 2009 14:04 PM
    Expert7120 points
    MJ,
    Since you are only looking for 0-3V out, I would recommend sticking with the single supply strategy as it stands the best chance at meeting your power and performance needs.  Here is a possible starting point for you.  If you truly need 100kHz bandwidth this pushes the power budget up a bit; however, if you can live with less bandwidth you can scale the OPA381 and OPA365 to something lower power such as an OPA364.  FYI-- you will have to scale the feedback resistor, compensation cap, noise filter, and OPA365 gain stage accordingly.   Note also that you should scale the reference voltage based on the output swing of the transimpedance amp, which in this case is the OPA381.  This reference voltage can be a divider off the supply (if it is linear) with a low power buffer such as an opa333.
    I hope this helps as a start.
    Matt
    Report Abuse
    • Reply
  • MJ16032
    Posted by MJ16032
    on Nov 09 2009 16:09 PM
    Prodigy220 points
    Great information.  Thanks for the help.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
