Hi there,
let's go deep into INA149 :-)
There is defined PSRR (power supply rejection ratio) in the datasheet as 120 dB. Then we can see POSITIVE PSRR vs FREQUENCY graph at page 8.
Plots in figure 16 and 17 cover 10 100 kHz bandwidth. WHAT HAPPENS FOR f>100 kHz?
I've attached my schematics. Please see, I've used AD629 as a placeholder as I've found it in my library :-)
OK - what's my problem?
It looks like power supply noise propagates to the output signal. I use TRACO TEN 5-2422 with 100nF ceramic + 4.7uF elyc caps at output.
INA149 has 100nF ceramic close to +12 and -12V and GND. I can see > 1 MHz noise and spikes in power supply voltage.
Could you please comment PSRR paraameter of INA149? Does > 1 MHz power supply noise propagates to the output signal easy?
What's your recommendation to increase INA149 immunity to power supply noise?
