Looking for similar amp. like OPA2350 but for single supply of 10V or 12V
Eli,
Since none of the standard op amps have internal ground, and thus all of their parameters are defined with respect to its rails, they ALL may be used as single or dual supply. Since no op amp fabricated on a different wafer process will exactly match the performance of OPA2350, and you do not specify the most critical specs in your application, I can only refer you to TI selection tool which you may use to find the most appropriate part for 10V or greater supply voltage:
