Hi everybody,
The datasheet for INA826AID says that the minimum single supply voltage is 3V. According to the revision history, it used to be 2.7V. As a matter of fact, the parametric search at www.ti.com/.../compare still lists 2.7V in the Vsmin column. And so do Digikey and Mouser.
Thanks to all of this, I got confused and used the IC in a battery-powered design, where the extra 300mV is non-insignificant.
So, what exactly is going to happen if I use a 2.8V supply? Which parameters are going to be degraded and how badly?
Also, is there a pin-compatible part that would perform better at lower supply voltages?
Thanks!
Bart
