I'm reviewing a change to a CCA were a changed was made to an INA129 Instrument Amplifier IA) Input Gain setting resistor circuit.
The change made is how the IA Gain Resistor is set by allowing the gain to be "adjustable" by using a serial of different resistors values being switch in or out using a CMOS Switches (e.g. CMOSADG1436 or ADG 1212). The IA Gain settable range is low (< 10 gain) measuring simple DC Voltages. The IA-Output is then feed to IC-Comparator as to trigger an event. This change seem very clever but I have some concerns this is a bad ideal.
Any thoughts are welcomed.
Byron
