Other Parts Discussed in Thread: OPA2333, TLV2333
Dears
I want to use TLV8812 to replace OPA2333, use the the same Sch,But the result is different. The application is to acquire two TS resistor, we use MOSFET to switch channel,the sch as follow
At the beginning of power up, the output of TLV8812 is same as OPA2333, after about 4-8hours, the output become unstable, the power supply COL_ADC has some noise,and when we switch channel by MOSFET, the input of TLV8812 become unstable too. We also test tlv2333, the phenomenon came up again, Would you pls give us some advice to check the circuit? Thanks a lot.
