I have an application where the customer is using the AMC1311 to pass an analog signal over an isolation barrier. The application uses a single-ended ADC and the datasheet shows an approach using an op-amp and several discrete components. The customer wants to know if there is a simplier, lower parts count way to do a differential to singled-ended conversion using only discrete components.
