Is there a way to either transition to the diagnostic state from the active state, or if you are in the active state put the watchdog on hold so it doesn't need to be serviced (or prevent reset).
The situation I am looking at is that the board is running, actively servicing the watchdog, and I need to flash the firmware, so I obviously don't want the TPS chip to cause a reset in the middle of that.
David
