Hola,
Do we need to put a VIT resistor as below location?
According to the datasheet description and it needs to use dividing resistors to calculate VIT resistor what value should be put, but the question is that I'm not using
dividing resistors to set sense threshold voltage because of I'm connect SENSE pin to VDD directly.
And we assumed that we don't need to put VIT resistor in our circuit but I found one issue when we tested our board, there is a pulse if we didn't put
VIT resistor, but the pulse will be disappeared when we connect VIT resistor between VDD and RESET pin.
My question is that should we need to put this pull up resistor between VDD and RESET pin?but why?we don't have dividing resistors in our circuit.
