  • Resolved
TLV3702-Q1: operation at below minimum voltage
Part Number: TLV3702-Q1
Hi
I would like to know how the device behaves when the input voltage is below 2.7V. (This is minimum voltage at single supply)
Does this device output low level ? or high level ? or unknown?
Our customer is concerned how this device operates when it startup.  Because some other device outputs the glitch during startup until it reaches minimum voltage.
Koji Hamamoto
  • Hi Hamamoto-san,
    I've assigned this post to the appropriate applications engineer, he will respond to your question.
    Karl
  • The output is unknown when the supply voltage is below the minimum level. It is kind of Hi-Z and a pull down resistor can make the output low in the undefined supply range.
    To find the latest information on power Switches, visit www.ti.com/powerswitch
  • In reply to Mahmoud Harmouch:
    Hi Mahmoud-san, Karl-san,
    I appreciate your prompt support. I suggested to our customer about your answer.
    They understood and would like to know how much pulldown resistor should be.
    Do you have any recommended value for it?
    Koji Hamamoto
  • In reply to K.Hamamoto:
    We do not have full characterization for pull down resistor but 10K should be working.
    Mahmoud-san
    That value is very helpful.
    Thanks!
    Koji Hamamoto
