• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Applications » Medical & High Reliability » Medical & High Reliability Forum » ADS5263EVM Configuration Confusion
Share
  • Forum
Options
  • Subscribe via RSS
  • Bryan Rabin
    Posted by Bryan Rabin
    on Jun 28 2012 09:21 AM
    Prodigy80 points
    I have connected the ADS5263EVM to a Virtex-6 FPGA.  Following Table-2 in SLAU344, I have set up the device to use all 4 channels in the transformer path for 16-bit ADC.
    I have used the following configuration for Channel 1, and followed the table accordingly for the other 3 channels:
    R80,R81 = Open ; R169,R170 = 0 Ω ; R35, R153 =Open
    Although Section 2.3 suggests that the inputs will use the INxA SMA ports, I am only able to obtain a signal using the INxB ports.
    Currently, I am able to capture a 1MHz input signal successfully, but I am unable to see any change in output when connecting a DC input signal.
    In the ADS5263 GUI, I have enabled 16X serialization in 2-wire mode.
    Is there something in the documentation that I have misunderstood or overlooked?  Why am I unable to capture a DC change?  And am I correct in using the INxB ports for my desired setup?
    Thank you in advance for your help.
    A/D converters ADS5263 ADS5263EVM
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
  • Guglielmo Sirna
    Posted by Guglielmo Sirna
    on Jun 29 2012 05:40 AM
    Prodigy180 points
    Hi Bryan,
    For setting up the 4-channles with 16bit and transformer, you should follow the schematic in SLAU344, page 32 and page 33.
    There are two groups of SMA ports: Group A (J27, J28, J29, J30) drive the OPAMP inputs; Group B ( J14, J16, J17 and J19) drive the transformer inputs.
    You have to make sure your input signals are fed into the correct SMA ports that drive directly the transformers: J14, J16, J17 and J19.
    Please note the silk screen label  "INxB", next to J14, J16, J17 and J19 input SMA ports,  could be misleading, since we also call A and B the 16bit and 14 bit mode...
    If you follow the schematic closely, you will see that what really sets the 16bit vs 14bit mode is the resistors configuration:
    R35, R153, R154, R155, R165, R166, R167, R168 shall be OPEN;
    R169, R170, R171, R172, R173, R174, R175, R176 shall be 0Ω;
    Let me know if this solve the issue.
    BR
    Guglielmo
    Report Abuse
    • Reply
  • Bryan Rabin
    on Jun 29 2012 08:33 AM
    Prodigy80 points
    Hi Guglielmo,
    That information confirms that my board is setup correctly.  The A/B labeling for different reasons is very confusing.
    The only issue I am dealing with now is the DC blocking.  I have tried the transformer and OPAMP paths and neither is able to detect a DC change in the input signal.
    Thank you for your help,
    --Bryan
    Report Abuse
    • Reply
  • Guglielmo Sirna
    on Jun 29 2012 09:29 AM
    Prodigy180 points
    Bryan,
    concerning the input DC blocking: all inputs have DC blocking. Please see the EVM schematic (SLAU344 page 31..33)
    The OPAMP inputs have  0.1uF DC blocking  cap: C62, C90, C110, C118.
    The input transformer would block the DC by definition. The transformers are Coilcraft WBC1-1TLB (http://www.coilcraft.com/wbc.cfm) and the bandwidth is 0.25MHz....750MHz.
    So, none of the input will detect a change in the DC level.
    BR
    Guglielmo
    Report Abuse
    • Reply
  • Bryan Rabin
    on Jun 29 2012 10:21 AM
    Prodigy80 points
    Guglielmo,
    Is it possible to modify the OPAMP path of the board in order to detect a DC change?
    --Bryan
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
